Leaky front forks - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 04-20-2010, 03:10 PM Thread Starter
Question Leaky front forks
I think the seals on my front forks have gone bad. Oil is leaking out the top and dripping down the pipes. Is it possible to fix them by myself and does anyone know how or is it worth the $200 to get them fixed.
Jumpman is offline
post #2 of 12 Old 04-20-2010, 04:00 PM
swingset's Avatar
Send a message via Yahoo to swingset
First off, might just be some grit in the seal, get a seal-saver or .004" feeler guage, and insert it into the dust seal, past the fork seal and wipe it around a few times. Often this can dislodge what's causing a minor leak. Cheap fix, if not.
If you want to do it yourself, it's really not very hard. Follow the manual, there are numerous youtube videos on traditional forks that will give you an idea of what's involved.
You don't need any special tools really other than a fork-seal driver, and you can make one out of PVC, or Rocky Mountain ATV has the Tusk brand for $30 something.
I'd rate it a 5 out of 10 for difficulty, easy if you've got some basic mechanical skills and decent tools.
Never met a dog I didn't like, a machine I couldn't break, or a woman I couldn't tick off.
swingset is offline
post #3 of 12 Old 04-20-2010, 07:05 PM
Often
Often the seals just have some junk behind the lips. If you clean them out well, they'll often return to proper sealing. The most effective way is to remove the forks and disassemble the fork tubes, which isn't a huge job, especially if you have a centerstand. Before you do, take a flashlight and take a very close look at the fork tubes to be sure there are no chips or dings in them, which will ruin seals in short order. If you find some, and they are minimal, some work with wet-or-dry sandpaper in 400-800 grit may smooth the tubes out enough to work. Didn't say how old your bike was. If more than a couple of years old, probably time to change the fork oil anyway.
Jimding is online now
post #4 of 12 Old 04-20-2010, 07:16 PM Thread Starter
It's a 2006. Thanks for the tips.
Jumpman is offline
post #5 of 12 Old 04-20-2010, 07:31 PM
What Kinda Bike Is That?
Black Lab's Avatar
Read here: https://www.stromtrooper.com/showthread.php?t=36808
Black Lab is offline
post #6 of 12 Old 04-20-2010, 09:36 PM
PhotoBiker's Avatar
If you replace the seals yourself, follow Black Lab's HowTo, AND have all the correct parts on hand, it would probably take a couple of hours to do.
It took me three weeks, but then I had the wrong part - twice. . .
-=Glen=-
(n1xf)
'10 R1200GS
'02 DL1000
'06 KLX250S
Check out my [URL="http://www.pbase.com/gsansoucie"]Photo A Day Gallery[/URL] or my [URL="http://www.flickr.com/photos/gsansoucie/"]Flickr Photostream[/URL]
PhotoBiker is offline
post #7 of 12 Old 04-20-2010, 11:58 PM
gir
gir's Avatar
For driving the fork seals, almost anything that is thin and curved and not too hard and can push the seal down will work. People have used a screwdriver covered in tape, I use a paint stirring stick. Just go around and push it in bit by bit, no problem!
'04 DL650
gir is offline
post #8 of 12 Old 04-21-2010, 01:29 AM
swingset's Avatar
True, anything will work, but you ever done it with a fork seal driver? Makes it a 2-second job, and you KNOW you're not ****ing it up. I used some pennytech stuff to do it, and I finally broke down and bought one....makes it so easy.
swingset is offline
post #9 of 12 Old 04-21-2010, 10:44 PM
Film negative
Here is an old dirt bike trick:
Use an old negative or piece of film strip to fish out the junk in seal. wrap the film around the fork and rotate it back and forth while pushing it gently past the dust seal and into the fork seal. The holes in the film strip will hold the junk as you pull it back out. Wipe down the fork and film strip and repeat. Cycle the forks in between cleaning and wipe down the forks again.
I just did this on my '03 and it fixed my leak.
If you do r&r the forks you can use a piece of pvc split vertically as a seal driver.
If you use belray waterproof grease between the fork seal and dust seal it will help to keep out the debris.
Current: '03 vee, '07 wee abs, and '01 xr650r.
Past: '73 cb350, xl500, 2x Ninja 600s, Radian 600, and '93 klx650r.
Other toys: '68 Bronco sport, '69 XR-7 Cougar convertible and '41 Teardrop trailer.
beau396 is offline
post #10 of 12 Old 04-22-2010, 01:54 AM
Stromtrooper.com Sponsor
SV Racing Parts's Avatar
Thumbs up Leaky front forks
You can get new OEM Suzuki fork seals and dust covers for both forks, shipped to your door anywhere in the USA, for about $60 all in,
If you would like a set to do the replacements yourself, just let me know and I will get you looked after right away,
Email me at [email protected] rather than PM for faster response,
Blair
SV Racing Parts is offline
Tags
fix. , forks , leaking , seals
