Tools for Servicing - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 04-19-2010, 11:00 PM Thread Starter
zenduddhist's Avatar
Tools for Servicing
Could I get some input on what tools would be handy to have in my shop for servicing and repairing my 2008 650? I would be interested in any opinions you have from basic tools up to the more special tools that may come in handy. Thanks in advance for your help.
Chris McCarthy
Upper Sandusky, OH
_____________________
2008 Suzuki DL 650 ABS Flat Black
2006 Suzuki DR-Z400S
2002 Yamaha Kodiak 400
1991 HD Sportster 1200 (sold)
1990 HD Sporster 883 (sold)
1982 Yamaha XT 250
1981 Yamaha YZ 125H (sold)
1980 Yamaha 400 Special (sold)
1979 Yamaha DT 100 (sold)
1975 Yamaha DT 250
1976 Honda ATC 90 (sold)
1974 Honda QA 50 (still have my first bike)
zenduddhist is offline
post #2 of 4 Old 04-20-2010, 12:27 AM
swingset's Avatar
Send a message via Yahoo to swingset
Beyond the basic metric wrenches/sockets/hex tools that address fasteners, here's what I'd consider essentials:
Air compressor & impact wrench, inflation guns, blow-gun tool, etc.
Bike lift (ATV-style or bench lift)...center stand at the minimum.
Set of metric impact drivers & socket-style hex drivers.
Manometer (homemade one works great)
Quality multi-meter & test probes.
Wire stripper/crimper and connectors.
Good set of needle-nose & long reach pliers.
Vice grips, clamp & normal style.
Large breaker bar.
Torque wrenches (1/4, 3/8 and 1/2)
Swingarm tool (can grind a socket to make)
Long reach screwdriver (for boots and clamps)
Filter wrench (rubber strap style works if you can't find a cap-style)
Oil changing tools (collector, long funnel)
Large & small punches & drifts (for bearings, etc.)
Rubber mallet & delrin hammer.
Bearing & race driver (Harbor Freight sells a great small kit that will service most of the Strom's bearings, they also sell a blind bearing puller that's handy).
43mm fork seal driver (Tusk brand from RockyMountainATV.com is cheap and works great).
Fork oil tool (cow-syringe with tubing works too)
Micrometer & Caliper (did I mention Harbor Freight yet? hehe)
Magnetic grabber tool, small inspection mirror.
Feeler guages
Spark plug socket (16mm, IIRC)
Lots of Belray waterproof grease
Hmmm...there's probably more but that will knock out most everything I can think of or have done.
I'm not a Wee rider, so some things might be slightly different but most stuff works on both bikes. BTW, glad to see another Ohio Strom owner! Welcome.
Never met a dog I didn't like, a machine I couldn't break, or a woman I couldn't tick off.
swingset is offline
post #3 of 4 Old 04-20-2010, 08:04 AM
12mm Hex.........
.....to remove the front axle (when changing tires and you must pull the wheel off).
mark444 is online now
post #4 of 4 Old 04-20-2010, 09:38 AM
steve68steve
Swingset's reply seems like a pretty comprehensive list - I'll just add some emphasis:
You NEED torque wrenches to work on this bike, IMO. Going by "feel," I've often been surprised by how far off my "feel" is. I've even stripped out a threaded hole by grabbing the wrong torque wrench.
JIS screwdrivers (the one in the toolkit is probably a JIS). JIS (Japanese Industrial Standard, or something like that) is a different pattern of Philips driver. An American Philips head will "fit," but you'll be amazed at how much better the JIS works. Long story short: I have stripped plenty of screws with a Philips (trying to remove them from 'factory' tightness), then gone back and eased them right out with a JIS. I've NEVER stripped a screw head with a JIS.
Metric allen wrench sockets. I found a cheap set at Sears for ~ $9. So many of the fasteners are allens with a specified torque.
