Walmart Air Compressor - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 04-18-2010, 03:45 PM Thread Starter
CoastalDefender's Avatar
Okay, so there's a consistent mention of a walmart air compressor in many of the under-seat kit threads here.
Which one is it? I hear "take off the plastic and it fits under the seat", and "cheap", but I can't find any model that looks like it would fit under the seat.
Any links?
[SIZE="2"]Meat is Murder.[/SIZE]
[SIZE="1"]Tasty, tasty murder...[/SIZE]
CoastalDefender is offline
post #2 of 9 Old 04-18-2010, 04:15 PM
These two fit under the seat...I think Walmart used to sell the Airman sparrow..not sure if they still do.
http://www.webbikeworld.com/r3/motor...irman-sparrow/
la-motor is offline
post #3 of 9 Old 04-18-2010, 04:49 PM
aldntn's Avatar
I'v used the "Slime" compact pump for a couple of years and have pumped a lot of air with it. The shape is perfect for under seat storage on the Strom. Got mine at O'Reilly's auto
09 DL650 ABS
MadStad + stock shield, JCW large topbox, Tuturo chain oiler, Heaterz grips, Suzuki hand guards, GIVI side guards, Aprilia Tuono mirrors, 36l Givi panniers, Richland Rick fork brace, Pipercross Air Filter
http://www.aldntn.bravejournal.com/
aldntn is offline
post #4 of 9 Old 04-18-2010, 05:23 PM
Colin's Avatar
In Canada the Airman Sparrow is sold under a different name through Canadian Tire.
I usually pick one up on sale for about $9.95. They work great for all tires including my 4psi Quad to my 50psi Trailer. I have one in each of my vehicles and it fits perfectly under the seat of the Strom.
Colin is offline
post #5 of 9 Old 04-18-2010, 06:47 PM
Stromtrooper.com Sponsor
happypuppy's Avatar
I took apart the case on the slime pump to make it smaller, and I had done the same with the Walmart unit earlier in the year. They look the same to me inside I suspect they use the same supplier. Both work well.
happypuppy is offline
post #6 of 9 Old 04-18-2010, 06:58 PM
PhotoBiker's Avatar
I have the Slime kit that came with a real neat case. I removed the compressor from the case and put it in a one gallon ziploc bag along with all the necessary tubes. It fits perfectly under the seat.
Oh yeah, this is the ONLY compressor I own by the way AND I do my own tires. This little 12v compressor will seat the beads on my rear in about 4 minutes.
It draws a lot of current, make sure you either connect it directly to your battery or on a circuit designed for 20 Amps. I have a Powerlet on my handlebar just for the compressor and I use a 20 Amp fuse.
-=Glen=-
(n1xf)
'10 R1200GS
'02 DL1000
'06 KLX250S
Check out my [URL="http://www.pbase.com/gsansoucie"]Photo A Day Gallery[/URL] or my [URL="http://www.flickr.com/photos/gsansoucie/"]Flickr Photostream[/URL]
PhotoBiker is offline
post #7 of 9 Old 04-18-2010, 09:06 PM
DXDL's Avatar
Slime pump from WalMart @ $17. Have bought one myself and one for my dad and one for my buddy. Works great.
2008 DL1000
42,800 miles
Saddleman seat, upgraded stator, Shinko 705's, Chain Alignment Spacer, SpeedoDRD Healer, ATV High handlebar, Zumo 395LM GPS,
LED Headlight bulbs Kit 50W 6500k Fanless, Tusk Folding Shift Lever Black/Silver, Wide Black Aluminium Foot Pegs, Foot peg lowering kit,
Givi engine guards, clutch lever push rod mod, accessory fuse panel under seat, up and back risers.
DXDL is offline
post #8 of 9 Old 04-19-2010, 11:03 AM
KZDon's Avatar
What name? I've asked at my local CT and get nowhere with the brilliant individuals behind the parts counter.
KZDon is offline
post #9 of 9 Old 04-19-2010, 11:22 AM
Lesman's Avatar
There are two slime pumps. One sold at Walmart(near me) is the bigger version. There was a sale(Auto parts store) last summer. After rebate it was $9.99 or $19.99. The small small pump will fit perfectly under a Strom seat. It works great.Just fixing a flat it will fill a tire in the 2-3 minute range. It gets very hot.
Les
I own the Bestest Strom in the World!!!!!!!!!!!!!!!!!!!!!
Lesman is offline
