Front wheel wobbles on brand new Vstrom - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 26 Old 04-12-2010, 09:53 PM Thread Starter
Hello,
My front wheel on my 1-month old 2008 DL1000 wobbles at about 45MPH? Any idea why? I have a 2002 Vstrom with Avon Distanzia tires and there is no wobble. Those tires are excellent. Are the stock tires junk? Thanks...
It's Nice to be important but it's more importan to be nice
2009 Suzuki Vstrom 650 (Light Grey)
2008 Suzuki Vstrom 1000 (Black)
2005 Yamaha DR 125 (Blue)
2002 Suzuki Vstrom 1000 (Drak Grey) **SOLD
2008 Kawasaki KLR 650 (Green) ** SOLD
2003 Kawasaki KX 125 (Green) **SOLD
1982 Yamaha Virago 920 (Black) **SOLD
Espanol is offline
post #2 of 26 Old 04-12-2010, 10:05 PM
Banned
Originally Posted by Espanol View Post
Hello,
Is 45 mph around 60 km/h?
I think they all do it (mine does, and it is not tire related; the other two I tried also do it), don't worry.
It will not turn into a tankslapper, I can ride for hours with my hands off the bars at that speed (and even around curves); the wobble never gets worse than about 1" of wobble at the end of the bars. The direction of the bike is not affected. I admit is is a bit disconcerting at first.
It is also only between 60 and 70 km/h.
Ride down a hill at that speed so you can take your hands off the bars (or use a throttle lock if you have it). Keep the hands near, but don't react prematurely. If it wobbles more than 1 inch or so, you may conclude you have a problem, if not, forget it and ride.
SittingDuck is offline
post #3 of 26 Old 04-12-2010, 10:36 PM
I'd be concerned with a wobble at any speed. Do not assume that either the factory or the dealership got everything tight.
post #4 of 26 Old 04-12-2010, 11:01 PM
Ruggybuggy's Avatar
New bike, take it back to the dealer. I've had two new vstroms with stock tires and never had the problem.
Some people are like Slinkies...... They're really good for nothing but still bring a smile to your face when you push them down a flight of stairs!
Ruggybuggy is offline
post #5 of 26 Old 04-13-2010, 12:31 AM
I agree, they are not designed to wobble...something is not right and it's a brand new bike so why screw around...back to the dealer and let them sort it out.
DL650A K7
StromTech is offline
post #6 of 26 Old 04-13-2010, 01:31 AM
K1W1's Avatar
Originally Posted by StromTech View Post
I agree, they are now designed to wobble...something is not right and it's a brand new bike so why screw around...back to the dealer and let them sort it out.
+ whatever number I am.
My Strom doesn't wobble a mm at any speed with smooth road and never has.
To the poster who says there is an 1" movement get you bike checked.
K1W1 is offline
post #7 of 26 Old 04-13-2010, 04:40 AM
Banned
Uh guys...
I hate to break it to you, but all bikes have a range in which they wobble if you let go of the bars.
The stroms just happen to do it between 60 and 70 km/h.
Let go of your handlebars once in a while, and you'll notice.
I'm talking about a hands-off, 10 km/h speed limited range here.
I'm not talking about a problem that can develop into a tankslapper.
post #8 of 26 Old 04-13-2010, 10:13 AM
V-Tom's Avatar
It's a pretty common issue on bikes including the Stroms.
Here is a summary of what I have experienced and what I have read about it here:
Not all bikes do it but many do. It tends to get worse as the load on the rear of the bike is increased and as the front tires wear. Some tires seem to be more prone to it but it happens with many different brands. When you put a new tire on the problem may disappear or get better for a while but as the tire weras it often returns.
People will suggest a fork brace, tightening the head bearings, etc and in some cases these things might help a bit but generally they don't make any real difference.
As long as it is easily damped by your hands there is nothing to be concerned about.
..Tom
SMIDSY detailed report.
V-Tom is offline
post #9 of 26 Old 04-13-2010, 10:43 AM
Before you accept it as a characteristic of your new bike there are a few things that can and should be be checked. IMHO, this is important as the bike is new and several things could have been done poorly at dealer prep or have manufacturing defects. First thing you should check is tire pressure, low pressure can induce wobble. Then get the dealer to check the bike over to ensure there are no issues with a defective tire or poor wheel balance, something out of alignment or loose etc.
DL650A K7
post #10 of 26 Old 04-13-2010, 01:40 PM
jokermtb's Avatar
If the wheel is "wobbling", you probably lost one of your wheel weights and your wheel needs to be rebalanced. you could also have a damaged front tire [even if it's new - who knows what the porter at the bike shop ran over after he built it up?].....
But, if you are experiencing "headshake" - the handlebars wanting to shake back and forth, then you have a whole nuther possible set of things to check - and I'd have the dealer check your new bike out one more time.
jokermtb is offline
