Another Rostra Install Done Today - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 1 Old 04-10-2010, 09:52 PM Thread Starter
Just posting a few picks of my Rostra Cruise install. Found an easy way to mount the cable. Drilled and tapped 10-32 on a small bracket that hangs out from the TB bracket. Pulled the front TB arm from the rear. Mounted the servo at the back end in front of the tail lights. I pulled the connector pins out of the plugs and soldered the CC wires to them and pushed them back in. Nice a clean and no wire cutting and heat shrinking, except for the switch wires.
DG
'09 DL1000 - Solid Black - Givi V46/V35, Givi Engine Gaurds, Rostra Cruise Control, Madstad Bracket, MRA VarioTouring Screen, Rick's Fork Brace.
GL1800 Gold Wing (no longer)
XR650L
CRF450F
dg512055 is offline
