Brakes - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 04-06-2010, 10:23 PM Thread Starter
sapperranger04's Avatar
Brakes
Where is the best place to order rear brakesw for my 05 wee. I think that i got them hot at the ERC and they dont seem to be gripping anymore. Probably glazed over. So anyway. I know of people talking about EBC brakes, but i cant seem to find a place to order them. Ill take suggestions on differant kinds as well. Im always out to save a buck, but not comprise dependibility. Thanks jason
--- SAPPERS FORWARD ---
K7 VEE / ?
K5 WEE / SGT. Strom
K6 KLR650 / Ol Thumpy
K6 KLX110
81 KLE100
sapperranger04 is offline
post #2 of 5 Old 04-06-2010, 10:45 PM
One good place is http://www.amotostuff.com/Merchant2/...e=dl650_brakes
Click the Sign In button and it will give you a chance to register for a discount.
I would go for black organic in the rear and bronze HH in the front. Blair at SVRacing has Galfer which is also a good brand.
post #3 of 5 Old 04-07-2010, 09:23 AM Thread Starter
Thanks GW ill give them a looking over.
K7 VEE / ?
K5 WEE / SGT. Strom
K6 KLX110
81 KLE100
post #4 of 5 Old 04-07-2010, 01:46 PM
If there is plenty of pad material remaining, you can put a piece of fine sandpaper on a flat surface and lightly sand the brake pad across that to remove a glaze. If the pads are really cooked, toss them. If the rotors have melted pad material on them (and it is often very hard to see), you can lightly sand the rotors. If you got the brakes really hot, the heat damages the brake fluid and new fluid is needed.
post #5 of 5 Old 04-07-2010, 02:53 PM Thread Starter
Wow, thanks for that info. Im going to go pull the pads and give it a light sanding right now, there probably a 1/4-1/8 inch of material left on the pad, so ill give that a shot till i order some new ones.
K7 VEE / ?
K5 WEE / SGT. Strom
K6 KLX110
81 KLE100
