Not another SW Motech Centerstand question.. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 04-05-2010, 03:19 PM Thread Starter
I just ordered my centerstand and was wondering if any one used Twisted Throttles spring puller tool or if it was really necessary. They are back ordered 3 weeks and I don't really want to wait that long to install it. Can it be done without it? Your hints/tips greatly appreciated. Thanks!!
deliverydave is offline
post #2 of 8 Old 04-05-2010, 03:23 PM
Simple answer-NO I just used a phillips head screwdriver, stick the screwdriver through the spring hole and rest the tip on the tang where the spring attaches and lever it right on, I did it on the first try, piece of cake.
Everyones normal till you get to know them:mod_lol:
2008 Yellow Wee with too many farkles!
jspoon is offline
post #3 of 8 Old 04-05-2010, 03:45 PM
garandman's Avatar
I used the string technique.
Learned about it in this thread. But that links to a VSRI thread that's broken.
garandman is offline
post #4 of 8 Old 04-05-2010, 06:55 PM
Coat hanger spring puller
I used a bent coat hanger wire with both ends firmly, repeat firmly, locked in large vice grips to form a 'U'.
Link is offline
post #5 of 8 Old 04-05-2010, 07:14 PM
Good sized flat blade screwdriver worked for me.
post #6 of 8 Old 04-05-2010, 07:55 PM
Prime's Avatar
Agree with the others...
I put an SWMotech centerstand on my Wee about three weeks ago and used a VERY LARGE screwdriver to pull the spring, it was very simple and took about 5 seconds, honestly. Hint: It must be a BIG screwdriver, for leverage.
"If everyone demanded peace instead of another television set, then there'd be peace" - John Lennon
"Every gun that is made, every warship launched, every rocket fired, signifies in the final sense, a theft,
from those who hunger and are not fed, from those who are cold and not clothed" - Dwight D. Eisenhower
Prime is offline
post #7 of 8 Old 04-05-2010, 11:43 PM
I used a flat blade screw driver too. But I pushed the spring past the attachment and then removed the screw driver. I don't remember how exactly but I don't think I really leveraged it against anything. I think there was room to just push it past the the pin it pulls on. I definitely don't think you should get a special tool for it as others above attest.
80 Honda CM400E
95 GSXR750W
06 DL1000
09 DRZ400S
BrianSSSSS is offline
post #8 of 8 Old 04-06-2010, 09:54 AM
I used a regular brake tool, it has a small divet in the end that rests on the tang and won't slip off as you're levering the spring on. Still a bugger though. My index finger still hurts where the spring popped it during one of many tries!
2004 Wee- Satin Black and set up for touring.
1961 Wife- also nicely farkled!
bananaman is offline
