Effect of freezing temps on Ride-On tire protection? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 04-05-2010, 01:23 PM Thread Starter
I have a question concerning the effects of freezing temps on the chemicals used in the Ride-On tire protection product. I'm having a set of Metzeler Tourances installed on my '07 wee this week and I'm considering using the Ride-On produce in the tires. My concern is that my wee sometimes sits in my unheated garage on the centerstand for days and sometimes weeks at a time from December through February, here in southcentral PA, will this have any adverse effect on the product?
Thanks,
Jeff
SoPaRider is offline
post #2 of 5 Old 04-05-2010, 03:52 PM
turboderek's Avatar
Send a message via AIM to turboderek
from http://www.ride-on.com/faq_technical.asp
Q: What is the shelf life of Ride-On (TPS)?
A: The shelf life of Ride-On (TPS) is 60 months in the original unopened containers. It is recommended that the containers be stored out of direct sunlight in temperature ranges of 20F (-7C) to 95F (35C).
Q: How does Ride-On (TPS) perform under extreme temperature conditions?
A: Ride-On (TPS) is effective from -40F (-40C) to more than 300F (149C). Ride-On works well in every season.
[url]http://www.turboderek.com[/url]
06 Suzuki V-Strom DL650 (105,000 miles of commuting and counting)
2004 KTM 85SX SM
2002 MZ 125 SM
2004 Triumph Thunderbird Sport
turboderek is offline
post #3 of 5 Old 04-05-2010, 11:24 PM Thread Starter
Thanks for the info turboderek, do you use Ride-On?
Thanks,
Jeff (SoPaRider)
post #4 of 5 Old 04-06-2010, 01:39 AM
turboderek's Avatar
Thanks,
Jeff (SoPaRider)
I've used it for many tires and miles. I am happy with the product.
2004 KTM 85SX SM
2002 MZ 125 SM
post #5 of 5 Old 04-06-2010, 04:31 PM
Stromtrooper.com Sponsor
happypuppy's Avatar
I use it as well for about 5 years and 3 bikes. I had used Slime before, but after a rather large puncture I used a mushroom and the slime made it pop out. I tried the same thing later with an old tire I was replacing on a bike that had no problems. It washes out of the rim well too. These things are not a replacement for a mushroom or string fix, but help. I pulled out a couple screws out of a tire before and it hissed a bit and then sealed up .
happypuppy is offline
