How is the factory heated grips wiring done?? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 10-03-2009, 06:08 PM Thread Starter
Smile How is the factory heated grips wiring done??
As in ... where does it go and how could I remove and replace it and obviously inspect it??
Cheers in advance :-)
MR_TiGGer is offline
post #2 of 5 Old 10-03-2009, 07:09 PM
The connector is behind the radiator.
post #3 of 5 Old 10-03-2009, 08:35 PM
steve68steve
I put the OEM heaters on mine recently. It was quite a bit of PITA just to ultimately shove some connectors together.
IIRC, the instructions start with "remove cowlings," and end with pivoting the radiator before you actually start plugging stuff in.
I read a few posts here about it at the time: some people even had to pull the fuel tank and airbox to find it, and it may or may not be taped up to a bundle of wires.
post #4 of 5 Old 10-03-2009, 09:22 PM
I removed the tank and the air filter cover and that provided room to reach down in the gap in front of the air box and plug the Eastern Beaver harness connector into the factory option plug. It's an easy route in. Do it when the tank is near empty.
DL650A K7
StromTech is offline
post #5 of 5 Old 10-03-2009, 09:42 PM
KZDon's Avatar
PM me and I will email you the OEM grip instructions. The sketches are reasonably easy to follow.
KZDon is offline
