Swingarm Removal Question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 10-02-2009, 12:47 PM Thread Starter
Question Swingarm Removal Question
Ok, so the time has come for me to replace the original chain on my 1000. I am trying to do this both the cheapest and easiest that I can. My initial thought is to get an OEM endless chain and sprockets because 1. dont have to buy a chain tool, and 2. seems stronger to me & 3. I got 20,000 miles out of the original.
Which means removing the swingarm. So who has done it? How bad was it? Any other opinions out there for best way to go about it?
Thanks for the help!
"[I]You can't be lost if you don't care where you are"[/I]
maddog5150 is offline
post #2 of 7 Old 10-02-2009, 01:47 PM
Removing the swingarm also requires a special tool. I'd get a chain tool if I were you. A riveted master link is as strong as the other links.
post #3 of 7 Old 10-02-2009, 02:11 PM Thread Starter
Smile True....
But I saw on this site the handy way to make a tool for the pivot bolt nut out of a socket. Looks pretty easy.:rolleyes:
post #4 of 7 Old 10-02-2009, 02:59 PM
Dread7's Avatar
I wouldn't go that route if it was me, I second the opinion of getting a chain and using a master link. I like the original sprockets, but IMHO DID X-Ring chains are superior to the stock chain.
However to each his own. As Greywolf says, get a good torque wrench
https://www.stromtrooper.com/forums/a...p/t-10896.html
Formerly clovett but changed to my gaming name
2004 DL650 1998 DR650 1994 CB1000 1992 DR350
2004 Z400 1965 Norton 650 1984 Honda XL200
1975 Suzuki RM125 1972 Yamaha 100 enduro
1971 Honda CT90 1968 Honda Z50A
Dread7 is offline
post #5 of 7 Old 10-02-2009, 03:00 PM
dtalk's Avatar
disclaimer: my comments here refer to the 650. I don't know how the 1000 might differ.
There are very good reasons to remove the swingarm at the same time that you replace the chain. It gives you an opportunity to lube the cushion rod bearings and swingarm pivot bearings. Failing to do so will eventually make you sad. I recommend getting the special tools you need (the swingarm locknut tool, and a hex key to fit the other side) and doing it for that reason.
That said, it's sort of a pain, the biggest hassle being the need to remove the exhaust, and the biggest challenge being finding a way to get the rear end of the bike off the ground. You can't use a swingarm stand, obviously, and I've read that a centerstand interferes with at least one of the bolts that you need to remove (I don't have a centerstand, so cannot confirm or refute this).
My solution: http://www.flyingjoke.org/motorcycle...sc/tiedown.jpg
The jack is under the centerstand lug. It worked fine for me. Read the manual, take your time, and it shouldn't be more than an afternoon. I can do it in just a couple of hours now, having been through it a couple of times.
Note: if you do get a chain with a master link, you can then do all the bearings without removing the stoopid exhaust. That only needs to come off to give the swingarm room enough to move far enough to let the chain past. You can reach all the bolts for lubing purposes without going to that trouble.
dtalk is offline
post #6 of 7 Old 10-02-2009, 04:54 PM
I did this on my DL650 and will probably do it again when chain replacement is necessary. My son made the "special tool" out of a socket in a half hour. I didn't have to remove the exhaust. I did lube the bearings. All told, not too difficult a job, at least on the 650.
keetmanaa is offline
post #7 of 7 Old 10-02-2009, 08:02 PM Thread Starter
Wink Thanks for the info so far...
:rolleyes:At this point I think I am still leaning towards removing the swingarm. I like the idea of getting in there and checking/lubing all the pivot points...
