You CAN push start a 'Strom... Battery question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 10-02-2009, 09:41 AM Thread Starter
rockitcity's Avatar
So the other day, I get geared up to go home from work and try to start my K7 Wee. Do the usual routine, key, kill switch, kickstand, clutch, and... nothing. No oil-pressure light, no starter. First thought is the various switches, clutch, kickstand, work the kill switch. All ok. Got off the bike and checked the lights with the ignition on and had only a faint glow from the headlights. Battery, of course. Maybe I accidently left the parking light on? Never did it before. No one else around, and I didn't have my Slime compressor with the jumper cable with me, so I pushed the bike up one level in the parking structure (whew, major workout!) and bump started it in 2nd gear on the roll down. Fortunately it worked, and I was able to keep it revved up on the way home. Seemed to take and keep a charge,as it started ok the next day.
Decided to top-off the charge, so I disconnected the battery and hooked it up to a charger that had two settings: 10 amp quick charge and a 2 amp trickle charge. At 10 amps, the charger immediately pegged the charge meter and backed off to zero. It did this several times, like it was trying to charge a short circuit. Figured this wasn't good, so I put the charger on 2 amp trickle charge. This seemed ok, and after 4 or 5 hours, it was showing no further charging activity, indicating a full charge. Reconnected the battery and started the bike fine. Lights seemed brighter than before the problem, and the starter spun right up.
Because of the unusual charger behavior, I'm concerned about the battery condition. My bike is 3 years old and has 10,400 miles on it. I have ridden it fairly regularly in the last year and a half, mostly freeway commuting, and it has not sat through any winter hibernation (hey, this is LA, year-round riding). Should I be concerned about my battery?
Bob
2013 Triumph Tiger Explorer
rockitcity is offline
post #2 of 17 Old 10-02-2009, 10:07 AM
Canis Lupus Ridin Sicles
GrayWolf's Avatar
Send a message via Yahoo to GrayWolf Send a message via Skype™ to GrayWolf
I can't speak to the charger behavior but my stock battery lasted 60,000 miles and through several Indiana winters (and I ride up to 20 below or so). So even sitting outside work in the winter it still was good. I also had it discharged several times and recharged it and continued riding. Your mileage may vary but I would keep riding and if it happens again then consider replacing it. Keep some wires under the seat to use to jump the bike in case there is no handy hill.
-GW
GrayWolf
"I wouldn't take a million dollars for the experience, but I sure wouldn't give a red cent to go through it again" -Chester Russell
2005 DL650 "Maelstrom"
2003 KLR650 "Lou"
1978 Triumph Bonneville 750 "Boomer"
Stromtrooper Offroad Club Member #3
Blue Wee-Strom Club #69
GrayWolf is offline
post #3 of 17 Old 10-02-2009, 10:13 AM
boroop's Avatar
Who cares how far you rode it? How many times did you start it? And do you do much off road riding where vibration may be a factor?
How likely are you to get stuck again if it is the battery? And what is that peace of mind worth to ya?
I'd say the cost of running into a good parts store with a battery checker would be worth your time/effort. Your battery, at three years old may be approaching its end of life.
I like knowing I can just jump on and go. But that's just me.
[color=blue]
[size=5]Bo Roop[/size]
2007 Suzuki V-Strom 650
[/color]
boroop is offline
post #4 of 17 Old 10-02-2009, 10:30 AM
V-Tom's Avatar
It's good you mentioned the age and low mileage!
Three years and the low mileage might give some insight as to what it wrong with the battery: You didn't say if you put a battery maintainer on it, and if you haven't then there is a good chance there is a sulfate build-up on the battery and this has shorted some of the cells out. Some chargers can remove this build-up but most likely you need a new battery.
If you ride it a lot more then the battery gets charged up and is less likely to sulphate. Short trips and long periods between use are very hard on a battery.
..Tom
SMIDSY detailed report.
V-Tom is online now
post #5 of 17 Old 10-02-2009, 11:02 AM
Meter?
Generally a failing battery will show a fairly quick self-discharge rate. If you have a meter, disconnect the battery, charge it fully. Disconnect from the charger, let the battery sit for a half-hour or so, measure the voltage, should be around 12.5-13.5 volts. Let the battery sit for a couple hours, go back and check it. Should be nearly the same. If there is a considerable drop (more than a half-volt or so) between the first and second measures, the battery is probably failing. If the battery seems OK, reconnect it to the bike. Check the voltage, let it sit for a couple hours, check it again. If you're seeing a big drop here, there's something drawing current on the bike. If not, I'd bet you left the parking light on. Doesn't take much to go from lock to parking light.
Jimding is offline
post #6 of 17 Old 10-02-2009, 11:48 AM Thread Starter
rockitcity's Avatar
..Tom
Thanks for the replies. I bought the bike when it was a year and a half old with less than 3,000 miles on it. Previous owner also had a DL1000 and decided he liked it better. I've put nearly 8,000 miles on it since I've had it. My morning commute is about 15 miles freeway, typically a steady 80 mph (LA traffic moves fast at 5:30 AM). Afternoon return is slower, but I lane-split, although I don't do it as fast as some of the squids on their sport bikes. I typically commute 3-4 days per week. It's not sitting around for too long at a time, so I haven't felt the need for a battery tender. I don't off-road at all. I have taken a few longer trips in hot weather (Laguna Seca, Northern California), but nothing that should kill a battery.
Checking with a meter is a good idea. Would an average motorcycle shop be able to test the battery, or would I have to go to a dedicated battery place? Sears, maybe? I have a feeling most places would try to find something wrong with the battery whether there actually was or not...
I appreciate the response.
Bob
post #7 of 17 Old 10-02-2009, 12:48 PM
garandman's Avatar
Bob
That's way too high a rate for a motorcycle battery, so it doesn't really indicate a problem or absence of a problem. Any idea of what caused it to go flat?
garandman is offline
post #8 of 17 Old 10-02-2009, 12:54 PM
randyo's Avatar
So, so I pushed the bike up one level in the parking structure (whew, major workout!) and bump started it in 2nd gear on the roll down.
it only worked cause there was still enuf juice in the battery to pressurize the fuel injection system
if the battery was completely flat, it would not have started
RandyO
IBA# 9560
07 Strom 1k (8x,xxx miles)
99 SV650 (135,006 miles)
82 XV920R
A man with a gun is a citizen
www.gbhsurvey.com
randyo is offline
post #9 of 17 Old 10-02-2009, 01:03 PM Thread Starter
rockitcity's Avatar
Probably left the parking light on although I didn't notice it when leaving and never have before. Easy to do though.
I usually hear the fuel pump whir when turning on the ignition. Didn't do it this time. Thinking maybe the alternator put out enough juice to charge the injectors? Anyway, I could never have push-started it on my own on flat ground.
post #10 of 17 Old 10-02-2009, 01:33 PM
JPryce's Avatar
Don't junk the battery just yet. Yuasa has a simple table you can use to get an idea about the health of your battery, or if your local shop has one good guy in the shop, they can test it in a matter of seconds for free.
I'd also quickly test the charging system by measuring the voltage at the battery with the bike running at ~3k.
2012 Super Tenere
2006 CRF50 with big-boy mods. :biggrin:
1973 RD350
JPryce is offline
