50 watt bixenon HID upgrade - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 26 Old 09-27-2009, 06:18 AM Thread Starter
Ducman69's Avatar
Going to order these for my 2008 DL650 VStrom unless someone knows why it may be a bad idea:
http://cgi.ebay.com/ebaymotors/50W-S...Q5fAccessories
50W SLIM BIXENON HID KIT: $145
Size (50W) :H4
Color temperture : 5,000K
Includes:
2 X 50w Slim Digital Ballasts
2 X 50w HID lamps and wire harness
2 fixing pads screws and wiring's
Instruction manual and warranty card
Warranty: 1 year
I had also considered asking if they have 3,000K 50 watt bulbs, which would produce a yellow light:
[URL="http://www.youtube.com/user/DumbDuck44"]Duc's WeeStrom Vlog[/URL]
Ducman69 is offline
post #2 of 26 Old 09-27-2009, 06:53 AM Thread Starter
Ducman69's Avatar
Ah and good news, they have 50 watt yellow bulbs as well! Whatcha think? I know you lose some light output with the yellow bulbs, but @ 50 watt they're still surely more than bright enough, and I would think would be really conspicuous.
Dear ducman-69,
Yes,we can offer 3000K (yellow golden) kit, no additioanal cost ,thanks
- hidsupplier
Ducman69 is offline
post #3 of 26 Old 09-27-2009, 07:53 AM
Forget the yellow go the 4300
Graham Downunder
graham downunder is offline
post #4 of 26 Old 09-27-2009, 07:59 AM
tmcgee's Avatar
+1
much better choice!
tmcgee is offline
post #5 of 26 Old 09-27-2009, 08:16 AM Thread Starter
Ducman69's Avatar
4300 has a bit of a yellow tint to it. 5000K is only a tiny fraction less bright, but is a more pure white light that would match my auxiliary LEDs.
I know they are the brightest though, thats why on my Vette I got 35W 5000K fogs and low beams and 50W 4300K high beams.
And yes, I weeear my sunglasses at niiight.
Ducman69 is offline
post #6 of 26 Old 09-27-2009, 09:05 AM
tmcgee's Avatar
4300k is supposed to be daylight. I'd go in the direction of 5000k as an alternative.
tmcgee is offline
post #7 of 26 Old 09-27-2009, 10:00 PM
The Golden Monkey's Avatar
I haven't used these myself, but I've read a number of warnings about retrofitting a headlight designed for halogen bulbs with HID. If the light source isn't in exactly the same spot as the filament in a standard H4, the light pattern will be off and likely a nuisance to other drivers.
Another issue is using HID for the high beam as well. If it uses a separate arc (rather than moving the bulb as some do), you won't be able to "flash to pass" since it takes a few moments for the arc to fire up.
As far as color temperature goes, the bluer lights (5000K and above) seem brighter, but actually do not improve vision over daylight-color bulbs. Stick with the neutral 4300K, unless you do a lot of riding in inclement weather -- then the yellow might actually help. And IMHO it's better for conspicuity if your headlights and aux lights are not exactly the same color, that way they stand out more.
2010 Triumph Tiger 1050se
2009 DL650A - sold
2005 DL650 - dearly departed
The Golden Monkey is offline
post #8 of 26 Old 09-27-2009, 10:08 PM
av8or's Avatar
Send a message via AIM to av8or Send a message via Yahoo to av8or
my understanding was that 5000-6500k was 'daylight'
[COLOR=Blue]'07 Suzuki DL1000 V-Strom[/COLOR]
av8or is offline
post #9 of 26 Old 09-28-2009, 12:46 AM Thread Starter
Ducman69's Avatar
Yup, thats my biggest fear. I have had good results on two cars though. Problem is, I can't seem to find anyone that says, "Here, use this brand, they stick very close to factory". :nonod:
These are simply telescoping, so not an issue, but even on the GENIVs out now thats no longer a big deal unless you flash religiously.
Nah, the 4300Ks are closer. They have superior lumen output as well, but it is countered IMO by the whiter light being perceived as brighter. Most LEDs are closer to 6K HIDs in appearance, but 5K I think is a nice compromise between looking "pure" and pumpin out the lumens, heh. Definitely sold on that, but was bouncing back and forth on the pure yellow light, since I've never used it. Think I'll skip it, since its getting no praise.
Ducman69 is offline
post #10 of 26 Old 09-28-2009, 03:24 AM
.... but was bouncing back and forth on the pure yellow light, since I've never used it. Think I'll skip it, since its getting no praise.
I've used yellow bulbs on a previous bike and both my stroms at one time or another, entirely for increased conspicuity. On each of the stroms, before I installed aux lights I swapped the left headlight bulb with a Nokya Hyper Yellow at 2500K. I actually like the combination of yellow and white light (the other headlight had a SilverStar) -- it seems to help me see irregularities in the road surface better, and of course it makes the bike a bit more visible in traffic. I wouldn't use yellow bulbs for both though, since they're not legal in the US for primary headlights.
2009 DL650A - sold
