Need electrical assistance: 12v to 6v transformer... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 09-25-2009, 05:09 PM Thread Starter
Quehele's Avatar
My wife and I use a radio com system (bike to bike) while we're on the road and I'd like to hard-wire them in to the bikes' power supplies. Our radios run on 4 AA batteries (6 volt). I've searched for a 12 volt to 6 volt transformer to no avail.
Any ideas on how to solve this problem will be greatly appreciated. Thank you in advance.
Jim
Wife's '09 DL-650: OEM hand guards - DL-1000 lower cowel - 16t counter sprocket - Givi windscreen - Air box mod w/ K&N air filter - GIPro gear indicator w/ ATRE - integrated comm system.
My '09 DL-1000: Air box mod w/ K&N air filter - GIPro gear indicator w/ ATRE - integrated comm system - Givi windscreen.
Quehele is offline
post #2 of 8 Old 09-25-2009, 05:28 PM
ozart's Avatar
Would this do it?
Also this TRANSISTORIZED VOLTAGE REDUCER is what I believe is used for older 6V vehicles to run the dash instruments.
ozart is offline
post #3 of 8 Old 09-25-2009, 06:07 PM Thread Starter
Quehele's Avatar
This is EXACTLY what I was after! You're a genius! All I need is two of these ($36.00 +/-) and I'm set. TRANSISTORIZED VOLTAGE REDUCER
Thank you again my friend.
Jim
Originally Posted by ozart View Post
Would this do it?
Quehele is offline
post #4 of 8 Old 09-25-2009, 06:41 PM
tmcgee's Avatar
Just FYI. Transformers work on AC, not DC.
tmcgee is offline
post #5 of 8 Old 09-25-2009, 07:02 PM
msi1259's Avatar
Your intercom units will likely run on 5 volts (borrow some rechargeables (which are usually only 1.2 volts each) to confirm), if so USB adapters may be a cheaper way to go (i.e. $6.95 http://www.gpscity.com/gps-city-12v-...hter-plug.html ) . A surplus USB cable plugged into a computer could also be used to test. (red and black wires in the USB cable)
DL1000K5
msi1259 is offline
post #6 of 8 Old 09-25-2009, 07:08 PM
ozart's Avatar
Jim
You're quite welcome.
ozart is offline
post #7 of 8 Old 09-25-2009, 07:10 PM Thread Starter
Quehele's Avatar
I spent 10 years as a journeyman motor control technician...and I realize that the word "transformer" is an AC term, not a DC term. But most people weren't electricians and may not know the destinction. I used the word transformer in a generic, colloquial sense.
Thank you for your input.
Quehele is offline
post #8 of 8 Old 09-25-2009, 07:50 PM
tmcgee's Avatar
Good luck with whatever converter you go with. There are lots of options. Parts Express is likely to stock a few.
tmcgee is offline
