Chain solvent - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 18 Old 09-24-2009, 11:58 PM Thread Starter
Chain solvent
I'm looking for a solvent to get all the old wax and grim off my chain. Being new to chain drive, I think i want a solvent to clean the chain the put the lube on it. Bring on the suggestions.
Thanks,
Jon
Boise
jonlindberg is offline
post #2 of 18 Old 09-25-2009, 12:01 AM
xen
xen's Avatar
Kerosene .
[COLOR="Blue"]'07 Vee[/COLOR]
:bom_!blank:[FONT="Comic Sans MS"][SIZE="1"] Let me recommend the best medicine in the world: a long journey, at a mild season, through a pleasant country, in easy stages.[/FONT] - James Madison[/SIZE]
[FONT="Century Gothic"][SIZE="1"]To mimic or to mock... that is the question.[/SIZE][/FONT]
[CENTER][SIZE="1"]* For Google Searching this site - type [FONT="Courier New"][I][URL="http://www.google.com/webhp?hl=en&q=site:stromtrooper.com"]site:stromtrooper.com[/URL][/I][/FONT] as part of your search words[/SIZE][/CENTER]
xen is offline
post #3 of 18 Old 09-25-2009, 12:12 AM
chris swann's Avatar
solvent
dont use solvent its bad for o ring chains
swann strom
chris swann is offline
post #4 of 18 Old 09-25-2009, 12:50 AM
Originally Posted by xen View Post
Kerosene .
+1 works great
DL1000K8
So what is it, am I a smart*** or a dumb***? Maybe I'm just an ***hole.
10guy is offline
post #5 of 18 Old 09-25-2009, 12:51 AM
I use enginge degreaser, spray it on, wait 10 minutes and brush the chain with a fingernail brush on all sides, hose it of and dry it a little and the chain sparkles, why screw around with kerosene, what a freakin mess!
Everyones normal till you get to know them:mod_lol:
2008 Yellow Wee with too many farkles!
jspoon is offline
post #6 of 18 Old 09-25-2009, 12:51 AM
$Whatever$
Heavy-H's Avatar
Kerosene .
Yep.............
06-DL1000 62000 miles....Sold...
Now 2012 Honda NC700X..37500 and counting...............FOR SALE
Now 2005 Suzuki Hayabusa..25000 and counting.......
Now 2018 Yamaha Super Tenere ES........
Heavy-H is offline
post #7 of 18 Old 09-25-2009, 06:30 AM
Would not what you're describing above be messy?. I use a Kettenmax chain cleaner with kerosene. All run off goes into the collector bag that hangs below it. And there's no overspray.
Kindest Regards,
-Will
willtill is offline
post #8 of 18 Old 09-25-2009, 07:25 AM
StabbyMcCutty's Avatar
WD-40
Easy to use easy to get. Spray and wipe off for "in between" cleanings. Use a brush to get in between the links and inner plates for fuller cleanings. Use something else to lube as the mineral oil in WD is too light and will just fling off. I'd suggest DuPont Teflon spray lubricant.
StabbyMcCutty is offline
post #9 of 18 Old 09-25-2009, 08:08 AM
Lotta
Lotta chain threads here, most of this has been hashed out. As mentioned, any solvent other than kerosene is likely to swell and/or soften the o-rings in your chain to the point of failure, at which point the chain will wear extremely rapidly. A somewhat dirty chain is more of a cosmetic issue than a problem. Mainly when you lube the chain you are providing lube for the sprockets as the o-rings hold the lube in the pivots, along with rust protection (other than the dry teflon lubes). So there's no need to really soak the chain with lube, which in turn attracts less dirt, which means less cleaning.
Jimding is offline
post #10 of 18 Old 09-25-2009, 08:23 AM
RichDesmond's Avatar
Kerosene works great, and doesn't have to be messy. I just get a shop rag wet with it and wipe the chain down. Takes less than 10 minutes to do a good job. Might get a few drops on the lift but that wipes right up. Wear latex gloves and your hands don't even get dirty.
Rich Desmond
RichDesmond is offline
