Removing panel holding Speedo/Tach - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 09-21-2009, 06:44 PM Thread Starter
Lesman's Avatar
What parts must be removed to get to the panel holding the Speedo/Tach. I have a LED voltage Monitor that died.I had installed the original on my aluminum shelf. I never cared for that setup. I want to install the new on in the little area above the tach/speedo. I haven't seen a sticky on this removal.
Thanks,
Les
Lesman is offline
post #2 of 3 Old 09-21-2009, 07:07 PM
If you have a 2004 or later model, see the pic. There are rivets that are removed as in http://www.vstrom.info/Smf/index.php/topic,1418.0.html as well as screws. #14 is one of two rubber grommets. They receive plastic spear heads that are stick in them so some effort is required to pull the pieces apart. The wiring harness has to be pulled out of the instruments when a little clearance is created to allow reaching it.
post #3 of 3 Old 09-22-2009, 09:33 AM Thread Starter
Lesman's Avatar
The instrument cover is just a cover? This is where I Want to put the LED.
I previously placed it on a Rick Hughes Shelf. The problem is there is movement in the wires when you turn the handle bars. I put the unit near the steering stem. The unit has failed and rather quickly.
Thank you,
Les
Lesman is offline
