Adventures in oil changing - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 29 Old 09-21-2009, 12:31 PM Thread Starter
When I bought this bike I decided that I was going to to all the servicing. I was going to learn it or I was going to become a cager again.
So...my first oil change on the bike (1000km). I got my filter ($15), I had some leftover AMSOIL from my VFR, a drain pan and lots of rags.
Taking the oil plug out went smoothy...the oil took about 5 minutes to stop poring out.
Took the filter off with the special filter wrench ($14)...no prob...more oil leaked out.
Once everything stopped leaking I gave it a quick wipe...took the new filter out and put some new oil around the O-ring and popped it on. (the two turns method once the filter touched the bike)
Then carefully measured 2.7 litres of oil.
All done...no issues...so then I turn on the bike and
BAM - PSSSSS - TURN OFF! TURN OFF! sh!t
The O-ring blew off the filter/bike. Oil sprayed out all over the driveway and up the side of the house. WHY!!!
Because I didn't check on the old filter if the old O-ring came off too!
What a complete nOObian thing to do.
So...hop over to the dealer, new filter and 3 litres of Suzuki's oil (total $35) and I do it all over again (minus the explosion).
Everything is fine
Except for a minor detail. If I run the bike for a couple of minutes the oil is above the Full line...is that okay?
stinkyfishy is offline
post #2 of 29 Old 09-21-2009, 12:46 PM
16171
First off...I can't imagine how one can miss the Filter Gasket when installing a new filter...I mean, your face is RIGHT THERE...but anyway...
Do you mean the oil is above the Full Line while the bike is running?? If so, don't worry about that, as the oil is checked with the engine stopped...and give it a good 5 minutes to settle before checking for most accurate reading. Level ground makes a big difference too.
BTD.
post #3 of 29 Old 09-21-2009, 01:06 PM
aldntn's Avatar
I've learned every lesson the hard many times over. Just forget it and go ride!
09 DL650 ABS
MadStad + stock shield, JCW large topbox, Tuturo chain oiler, Heaterz grips, Suzuki hand guards, GIVI side guards, Aprilia Tuono mirrors, 36l Givi panniers, Richland Rick fork brace, Pipercross Air Filter
http://www.aldntn.bravejournal.com/
aldntn is offline
post #4 of 29 Old 09-21-2009, 02:38 PM Thread Starter
BTD.
Well the Gasket is black, the filter is black the oil was black and I was doing this in the shade so you have to give a guy a break
The oil level is above full after the ride and then depending where I put the bike on the center stand I get either the full line or above.
I did do this with a level across the rack to make sure that I wasn't seeing things. But it is taking more than 5 minutes for the oil level to go down...is that normal?
post #5 of 29 Old 09-21-2009, 02:51 PM
On the drz suzuki recommends 3 minutes running and 3 turned off. My vee seems to like the same process. Yes it takes a few minutes after you turn off the bike for the oil to settle and so you can get an accurate level.
DL1000K8
So what is it, am I a smart*** or a dumb***? Maybe I'm just an ***hole.
10guy is offline
post #6 of 29 Old 09-21-2009, 03:03 PM
The oil level is to be established with both wheels on the ground snd the bike held vertically. If the bike is on the center stand, the oil level should appear high since the sight glass is in the front of the engine. I like to use the center stand as it is convenient and found that a tiny air space above the oil is perfect.
post #7 of 29 Old 09-21-2009, 04:14 PM
Experience is the lesson you get AFTER the test. We've all been there...
ronnielyons is offline
post #8 of 29 Old 09-21-2009, 06:47 PM
bigboy292000's Avatar
Ah yes, the famous double rubber gasket trick. Mine ended similarly, except I saw a rapidly expanding pool of oil under the bike (accompanied with that sinking feeling) rather than spraying all over the place.
Now I make sure.
09 WABS w. some farkles & teeth
[URL="https://www.stromtrooper.com/showthread.php?t=35638&page=3"]Strom Squadron Member #5[/URL]
bigboy292000 is offline
post #9 of 29 Old 09-21-2009, 07:13 PM
jackpiner57's Avatar
Everything is fine
So you're a service tech at which dealership? :lol:
"Build a man a fire and he'll be warm for the night. Set a man on fire and he'll be warm for the rest of his life." - Confuseus
jackpiner57 is offline
post #10 of 29 Old 09-21-2009, 07:51 PM
Everything is fine
Ignore all of our caustic comments and pay attention to what GW says. Oh, BTW, you're gonna win the dumbest post of the week. Welcome to hell.
elbrown is offline
