Dupont Multipurpose Dry Lube With Teflon - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 18 Old 09-04-2009, 04:46 PM Thread Starter
NordStrom's Avatar
Location: beautiful Vancouver, on the Wet Coast of Canada
I'm not happy with several chain lubes that I've tried to date and would like to try the Dupont multipurpose dry lube that others have recommended on this site. I have not been able to locate this product in Vancouver. Maybe it doesn't get distibuted in Canada. Does anybody know a Canadian distributor? Failing that I'll pick some up on my next trip south of the border. Which big box stores carry it in the US?
Thanks,
NordStrom
NordStrom is offline
post #2 of 18 Old 09-04-2009, 04:58 PM
16171
Lowes carries it...and several online places sells it by the case...which may be a good option if you can't locate it in Canada.
BTD.
post #3 of 18 Old 09-04-2009, 05:07 PM
I need to find another supplier too. I'm in Ft. Wayne, IN., we have 3 Lowe's here in town & they all quit carrying it earlier this year.
I live in my own little world, but it's OK, they know me here.
SlingBlade is offline
post #4 of 18 Old 09-04-2009, 05:14 PM
PNWStrom's Avatar
If you have any "ACE Hardware" stores nearby they carry it. Good luck.
2013 DL650A
2009 DL650A-Gone to a good home
2009 KLR-Gone to a good home
PNWStrom is offline
post #5 of 18 Old 09-04-2009, 05:30 PM
bigboy292000's Avatar
You can also get it at online places like Amazon...
09 WABS w. some farkles & teeth
[URL="https://www.stromtrooper.com/showthread.php?t=35638&page=3"]Strom Squadron Member #5[/URL]
bigboy292000 is offline
post #6 of 18 Old 09-04-2009, 05:40 PM
mtnbiker's Avatar
Try this.
I called Dupont a few years ago and was told they do not have a Canadian Distributor so I have been using Super Lube which is the same Telfon based lubricant I use on my Mountain Bike. I have been using it for over 12000km and the chain shows no wear. Here is the link:
http://www.mec.ca/Products/product_d...=1252099813319
Cheers,
Mark
2006 DL1000
mtnbiker is offline
post #7 of 18 Old 09-04-2009, 05:56 PM
Thanks,
NordStrom
Lowe's carries it, but ASAIK, so far, they're only in Ontario. If you cross the border by car from time-to-time, bring some back. If not, send me a PM and I'll see if I can help.
We use DuPont Multipurpose exclusively, and aside from being cheap, it doesn't fling off or drip, and seems to work great.
jonl is offline
post #8 of 18 Old 09-04-2009, 08:13 PM
WeThereYet's Avatar
Lowes in Bellingham. Ace Hardware in Linden. Call first to make sure they have enough to make it worthwhile going.
WeThereYet is offline
post #9 of 18 Old 09-04-2009, 08:43 PM
Oxblood's Avatar
Gunk has a similar lube called Liquid Wrench Dry Lube with PTFE. You can get it at most Lordco outlets. I have also heard Boeshield T9 works well, and you can get that at Lee Valley. I had not thought about Super Lube, but just checked their web page, and it sounds similar to the DuPont product.
Oxblood is offline
post #10 of 18 Old 09-05-2009, 07:41 AM
Bellingham big box stores. Lowes is easy to find and had lots and lots of it on display right up front. Buy 2 cans, have lunch somewhere and ride home.
Goggle Lowes locations and they will map it out for you. It's so easy even this caveman did it.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
