Pelican Boxes are Sweaty - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 08-31-2009, 09:35 PM Thread Starter
Ducman69's Avatar
For those using Pelican boxes as your side-cases, have you noticed that your boxes get sweaty inside near the metal screws?
I know Houston is more humid than most of the country, but I sprayed the thing down with a hose and it didn't get wet, but if I open it up in the morning theres dew and some droplets settled in the bottom corner from the metal screws.
I covered them completely w/ silicon to no avail. Any ideas, or should I just try to insulate them even better, and if so w/ what?
[URL="http://www.youtube.com/user/DumbDuck44"]Duc's WeeStrom Vlog[/URL]
Ducman69 is offline
post #2 of 15 Old 09-01-2009, 01:26 AM
Boondocker's Avatar
Both sides or just the exhaust side?
How about some of those dehumidifier packets?
Boondocker is offline
post #3 of 15 Old 09-01-2009, 01:53 AM
Canvas6st's Avatar
Humidity
Humid air trapped inside the air-tight boxes will probably condense as the night temps drop, especially around the metal screws which should be colder than the plastic.
I'm no scientist. Heck, I don't even have pelicans, but that'd be my guess.
[SIZE="1"]Orange K9 Wee - Givi guards and screen, Zuk hand-guards, Madstad, Rick's fork brace, Shad topcase, Sargent seat, Rox risers, Vessel luggage bracket and sheepskin, Tuono Mirrors, CL-850 bags, Wolo horn, Powerlet.
[/SIZE]
Canvas6st is offline
post #4 of 15 Old 09-01-2009, 03:57 AM Thread Starter
Ducman69's Avatar
Both sides, more on the left non-exhaust side if the bike is on the side-stand.
Ducman69 is offline
post #5 of 15 Old 09-01-2009, 09:35 AM
Yuppers, that would be the reason. It's condensation, forming from within, not moisture getting in from outside.... Well, *technically* it come in with the air you close in it, which, of course, came from outside, but..... What was the question again??
Oh! Right humidity... Yeah, it's just humidity condensing inside the box. Dessicants will help, but only until they become saturated too.
gijoecam is offline
post #6 of 15 Old 09-01-2009, 09:41 AM
I have to say that I have never noticed my Pelicans forming any condensation inside of them. And I live in a very humid climate (Maryland).
Kindest Regards,
-Will
willtill is offline
post #7 of 15 Old 09-01-2009, 10:48 AM
dtcjem's Avatar
I have pelicans and have never noticed any moisture from condensation or other.
09 DL650 ABS - Shad 37L top box / OEM Center Stand / Garmin 60CSX / Givi Bars / Caribou 37L Top Load / OEM Handguards / Madstat / AirHawk /GenMar up and back / Sirius Radio /Starcom1/More to come
<a href="http://www.fuelly.com/driver/dtcjem/dl650" target="_blank"><img src="http://www.fuelly.com/smallsig-us/43311.png" width="115" height="40" alt="Fuelly" title="Share and compare MPG at Fuelly" border="0" style="border:solid #ccc 1px;padding:4px;background:#fff;"/></a>
dtcjem is offline
post #8 of 15 Old 09-01-2009, 03:56 PM
Capt775's Avatar
I'd have to say no on the condensation. I've got 1550's on mine and have never had it. I live in Looosyana. Hot, humid, wet.
We've used Pelicans on our equipment here for years to carry EMS supplies, drugs, bandages, etc. Never had condensation or moisture issues that I can remember.
I'd check the gaskets good, maybe use a light coat of PJ, (petroleum jelly, not Peanut Butter and Jelly) on the gaskets.
I started out with nothing, and still have most of it.
[IMG]http://i182.photobucket.com/albums/x20/capt775/VisitedStatesMap.jpg[/IMG]
Capt775 is offline
post #9 of 15 Old 09-01-2009, 04:14 PM
Take an empty pelican box, seal it at 95 degrees with 100% humidity, then drop the outside temp to 50. I guarantee the moisture is going to condense on the inside of the case. It's the exact same thing that occurs when you take your 50 degree glass of water outside on a 95 degree/100% humidity day (just turned inside-out): Condensation.
Where else could that moisture be coming from but the air?? If there's nothing in the box when you close it up, there's nothing to absorb the moisture. In a medical kit, or if there's gear in it, the *stuff* can absorb some of that excess moisture when the temp drops below the dew-point. If the box is empty, or the *stuff* can't absorb the moisture, it condenses. It's just the way it works.
gijoecam is offline
post #10 of 15 Old 09-01-2009, 07:42 PM
swingset's Avatar
Send a message via Yahoo to swingset
I have some Kinetics cases (very similar to Pelican/Caribou), but they were military cases and have a pressure release cap, if you unscrew it on a hot day it keeps the interior from building condensation.
Dunno if other cases have these, but it's easy enough to fab up.
Never met a dog I didn't like, a machine I couldn't break, or a woman I couldn't tick off.
swingset is offline
