vibration noise at instrument cowling fix - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 08-30-2009, 11:18 PM Thread Starter
Couple weeks ago a new noise appeared and grew that is clearly the black plastic cowling where the seam is at top middle in front of instrument cluster. When I rev bike I can press with hand and quiet it immediately by just pressing on top center to press that joint gap together. Fasteners appear tight.
I tried something easy by just pressing some electrical tape in seam and may have helped only a little a bit but it is still there (notably at higher RPM accel or when backing down). I was thinking of maybe loosening a tiny bit and putting a bead of black RTV sealer and tightening after it sets up but not sure..
Before I went on to other ideas I thought I'd check to see if others has this and found a good fix.
Any fix ideas that worked?
[SIGPIC][/SIGPIC]2007 DL650 - 032510; HB Gobis, Bestem 46L, Sasquatch rebuild and shock spring, MRI shield, Afrika Twin CStand & guards, Fenda extenda, Ricor intiminators, stebel horn
2006 DL650 - Dec 08; rear ended/totalled 091609
1983 R80ST - 1984 to 2009
1979 750 Bonneville - 1980 to 1984
1973 750 Tiger (cross country 1976; stolen 1980)
marku is offline
post #2 of 7 Old 08-31-2009, 12:00 AM
I'll be watching this post.
My buddies Vee runs much quieter than mine, and has no plasti-rattle.
I'm thinking 2-Bros will be the most effective fix.
slick_kipper is offline
post #3 of 7 Old 08-31-2009, 12:13 AM
There are a pair of rubber doughnuts #14 in there that snug the parts together as well as keeping them from rubbing. Maybe you are missing one or both.
post #4 of 7 Old 08-31-2009, 01:09 PM
daxsonvt's Avatar
I have the same problem, but mine stems from different rubber pads. I am missing two rubber pads that adhere to the top of the plastic gauge cluster, between the gauge cluster and the headlight cowling. I found that with higher RPMs if i reached up and pinched the joint, the vib went away. Usually occurred at ~6500 and up.
daxsonvt is offline
post #5 of 7 Old 08-31-2009, 03:03 PM
No vibration or noise but I do have a gap of maybe 1/8 inch between the instrument cluster and its base. Is this common? Probably came from heat distortion over the years (2004 DL650). I have black Gorilla Tape covering the gap.
keetmanaa is offline
post #6 of 7 Old 08-31-2009, 03:18 PM
I had a vibration coming from the left side where the top black plastic meets the side fairing. After checking it out I discovered one of the rubber grommets (donuts) was missing where the top plastic connects to the fairing. I grabbed a package from Autozone and popped one in, problem fixed.
pig385 is offline
post #7 of 7 Old 08-31-2009, 09:05 PM Thread Starter
sounds like grommets
thanks for the replies. Interesting, I had bike in shop about month ago and they took tank off --and maybe "lost" something. I also noted just looking at bottom front before I posted this that I think I am missing plactic snaps shown in diagram that go up from bottom as they were open holes.
I actually never took any of that apart when I previously took tank to do air cleaner as I followed Sheps instructions post and you can just remove selected fasters and flex plactic cowling enough to slide it out. I wonder if shop decided to take all apart?
thanks for all tips -- and diagram GW.
[Darn - now I have to take all that stuff apart - maybe my generic grommets from HArbor Freight will fit missing ones]
marku is offline
