Dyno tuned - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 08-30-2009, 09:05 PM Thread Starter
Dyno tuned
Hi i just got my dl 1000 done with pc3 and leo vince pips and a k&n filter right now it running 95 foot pounds of torque and 93 hp is that a big gain or not bad i ask them when they tuneed it and they said they didn't know. and whats a stock one runing.
jkavon is offline
post #2 of 16 Old 08-30-2009, 09:30 PM
LarryB's Avatar
My post was all wrong after the OP edited his.
[I]If you're not moving forward, you're probably in somebody's way![/I]
Current ride:
2006 Yamaha FJR1300AE, Cerulean Silver
2005 Suzuki DL1000, blue - sold
LarryB is offline
post #3 of 16 Old 08-30-2009, 09:53 PM
16171
Pull that Map and post it up!!!
BTD.
post #4 of 16 Old 08-31-2009, 07:09 AM
Jeff Kushner's Avatar
Originally Posted by jkavon View Post
Hi i just got my dl 1000 done with pc3 and leo vince pips and a k&n filter right now it running 96 foot pounds of torque and 98 hp is that a big gain or not bad i ask them when they tuneed it and they said they didn't know. and whats a stock one runing.
Something doesn't sound right with your numbers....98hp/96fp. The torque figure is too high for this engine. Typically, we'd expect to see a # in the low 70 range not nearly equal to the HP rating. Don't take this the wrong way...it's always hard to tell when you are reading what someone wrote but I'm not saying that you are bs'ing us...just that you may have written down the wrong number for the torque. The HP sounds right and you can pick up a bit more by cleaning up the intakes. It's not worth it to most people since you'd have to remove the heads to so it.
If you really are producing 96fp, call the shop and ask them to email you a copy of the sheet so you can post it...I'd be curious as to where in the rpm range you were getting the torque that high.
jeff
Present only:
My VStrom 1000 K7
Stock bikes: a
purple '74 RD350 in great shape,
'72 H1,
1975 GT550,
All-original 1975 H2 750 triple (purple of course),
Modified bikes:
1974 H2 750(my go-fast), a scary fast & fully ported street machine!
'82 Yam 650 Turbo- running 18PSI, Be sure to be pointed where you want to go!
'75 GT550 built up & ported,
'75- H1 wrist-rocket- HOLY GOD ALMIGHTY!
'75 S1 Kaw 250 baby triple w/ lifted and ported 350cc cylinders/28mm flatslides
To-Restore list: '72 H1, 1-'75 H1, 1974 GT750
Jeff Kushner is offline
post #5 of 16 Old 08-31-2009, 05:31 PM Thread Starter
hi
Yea i know its strange its running 95 foot pounds of tourque and 96 hp i have the sheet right here if i could show you i will, i could scan it or some thing and post it i will it showing 95 foot pounds and 93 hp, but the bike was realy hot it was on the 3 heat gadge so they said that the hp would be about 96 if it was cool but the tourque is true aand it is at 5500 were it got 95 foot pounds of tourque sory about the 98 i messed it up for a 3 really sorey but yea the even said when the did it that the never seen that big of a tourque jump before when i send it were do i put it.?
jkavon is offline
post #6 of 16 Old 08-31-2009, 06:00 PM
I don't buy the torque figure either. You might have a sheet that says that, but no way can that be accurate. I'm not accusing you of lying, I have no doubt the shop told you that figure and printed it on a dyno sheet but the numbers just don't jive with the rest of the real world.
Not even professionally built race TL's with big-bore kits come close to that. No way are you getting a Vee there with just slip-ons and a powercommander.
Just as an example, here's what it took for one of the racers over on the TL forum to get a TL1000S (which makes more HP STOCK than a Vee) up to 142bhp and 86 ft/lb torque:
100mm (+2mm) JE High Compression Pistons
Bored and Replated Barrels
Flowed Heads
Stainless Flat Head Valves
1040cc, 14:1 C/R, 0.9mm Squish
JHS Stage 2 Race Cams c/w vernier Cam Gears
Arrow Rods
Lightened and Balanced Crank
TLR Crank Cases
Lightened Flywheel
Removed Scissor Gears & Decompressors
Removed Main Clutch Side Scissor Gear
Pre Production 6 Spring Billet Clutch Basket and Centre
Barnett Clutch Springs
Full TLR M4 System
K&N Filter
Power Commander
Custom Fabricated Alloy Oil Breather/Seperator and Additional Vent from Front Cam Cover
Wingspan is offline
post #7 of 16 Old 08-31-2009, 06:02 PM
jawmail's Avatar
Check back with the shop, something is amiss. They missed something. If your max torque is at 5500 rpm that means your max hp is also at roughly 5500 which is not possible with this engine no matter what you do. (hp= (torque * rpm)/5250)
2007 DL1000 faster blue,bone stock, Givi 52L top case. center stand, heated grips, 2006 XR650L sold, 1997 Honda CR250R smoker sold, 1982 KZ1000ELR Eddie Lawson version sold (sad), 1976 Honda 550-4 sold.
jawmail is offline
post #8 of 16 Old 08-31-2009, 06:07 PM
Hold on a sec, just thought of something.
Are you sure the dyno sheet doesn't say 93hp and 95 Nm?
95 Newton meters would convert to 70ftlbs, which is exactly what you'd expect out of a Vee.
Wingspan is offline
post #9 of 16 Old 08-31-2009, 06:07 PM
I found this
http://www.holeshot.com/dynocharts/dyno_dl1000.html
I stumbled accross this. It should give you some comparrison value.
DM
[SIZE=1][FONT=Comic Sans MS]2010 dl1000se Red[/FONT][/SIZE]
[SIZE=1][FONT=Comic Sans MS]2009 dl650 Black abs - Sold[/FONT][/SIZE]
dm50 is offline
post #10 of 16 Old 08-31-2009, 06:12 PM Thread Starter
yea i dont know my graf it alot different then that not really sure mine stats ant 90 at 3500 and goes to 95 at 5500 and at 8000 it at 85 nm then i guess they told me that it was the tourque but hard to stay i know i thought it was wrong to and the max hp is at 8000
yup that what it means 70 fpt haha sorey about that guys so thats not really that great then after all thanks alot guys for the help lol tha t sure makes me feel stupied
jkavon is offline
