Help! My mirrors are awful. Any remedy for this? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 08-28-2009, 11:50 PM Thread Starter
The mirrors on my 2006 DL650 will not stay in the position I put them in. When I get up above 70mph the wind pushes them towards me and all I can see is myself. It's really annoying and I'm not sure what I can do about it. My right mirror is definitely worse then the left.
I tried searching the forums but didn't see any threads about this so I thought I'd ask you guys if it's a common problem or if I just have a couple crappy mirrors.
Thanks for any input,
Erich
soggynuts is offline
post #2 of 14 Old 08-29-2009, 02:15 AM
silverstrom's Avatar
Is it the mirror that's turning or the whole thing including the stock? If it's just the mirror, try rotating the mirror to a different position to see if you can find a tighter position.
I've never heard of the problem before.
SS
DL650K7
1985 RZ500
1986 NS400R HRC
1987 RG250
1987 TZR 250
1988 RGV 250
1989 RZ 350 F2
1990 RZ 350 N2
silverstrom is offline
post #3 of 14 Old 08-29-2009, 02:49 AM Thread Starter
the entire stock, just above where it is attached to the bars
post #4 of 14 Old 08-29-2009, 03:05 AM
LordSmoke's Avatar
IIRC, the stock mirrors are crap. The adjustment collar snapped on mine as soon as I tried to adjust them. I replace with cheap, long-stem rectangular EMGOs from jcwhitney, but don't see them available now. Anyway, aesthetically, they disappeared on the bike and are rock steady in application.
I do recall one "glass" being not correctly seated when I got mine. A dip in some boiling water softened the plastic enough for me to snap it into place.
See other options here: http://www.vstrom.info/Smf/index.php/topic,10936.0.html
Mine are the third pic down.
PS: Oh, just noticed the link to JCW still works: http://www.jcwhitney.com/autoparts/I...D:100000146321
2014 BMW R1200GSW (APR14 - )
LordSmoke is offline
post #5 of 14 Old 08-29-2009, 06:55 AM
CanadianFZ6's Avatar
There is a collar/locknut under the rubber boot there. Just position it where you want then tighten the collar with a wrench...
2015 DL650AL5 in Blue
CanadianFZ6 is offline
post #6 of 14 Old 08-29-2009, 07:47 AM
BOURBON BOY's Avatar
After you slide up the rubber boot,the bottom set of wrench flats tightens the entire mirror assembly to the bars. Tighten it 1st, but don't go nuts on it-it is possible to strip out the thread base! Once you have it tight, hold the bottom flat with your wrench and loosen the top, this is the flat that lets you pivot the actual mirror anywhere you want it, you may have to loosen it quite a bit, mine were extremely tight. There is a collar that compresses the mirror stem and holds it in place. I didn't like the stock mirrors, and swapped them out for a set of different mirrors, but they all work about the same anyways. Cheers-BB
2012 Wee
BOURBON BOY is offline
post #7 of 14 Old 08-29-2009, 11:17 AM
gregfish's Avatar
Go with the Aprilia Tuono mirrors. $20 each from a dealer and they bolt right up. Rock solid and they reduce turbulance also.
gregfish is offline
post #8 of 14 Old 08-29-2009, 12:22 PM
bigboy292000's Avatar
I heard though they provide less rearward vision?
09 WABS w. some farkles & teeth
[URL="https://www.stromtrooper.com/showthread.php?t=35638&page=3"]Strom Squadron Member #5[/URL]
bigboy292000 is offline
post #9 of 14 Old 08-29-2009, 12:59 PM
boroop's Avatar
I've not noticed much difference after having mine installed for a few weeks. I can see more of the stuff behind me and less of my shoulders & arms... so even if they have less reflective surface area, I'm seeing more of the stuff I need to see in traffic.
I think they're a nice addition to the V-Strom. Plus my stock mirrors were worthless is the rain since they were fogging up as soon as it began misting. They more than likely started separating at the seams and let water in behind the glass. :cursing:
[color=blue]
[size=5]Bo Roop[/size]
2007 Suzuki V-Strom 650
[/color]
boroop is offline
post #10 of 14 Old 08-29-2009, 01:46 PM
I dig it... thanks...
Anyone know if this will work with stock heated grips module?
