dust in rear wheel - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 08-28-2009, 07:44 PM Thread Starter
dust in rear wheel
hello fellow wee riders here in south africa we have very dusty roads almost like powder and i am experiencing excessive build up of dust on the rear wheel so much so that only the valve cap is visible on a long dirtroad hauls.can anyone advise me on how this problem can be rectified and has anyone expirienced the same problem.this eventually interferes with the balancing of the rear wheel making the bike uncomfortable to ride.
dustmite is offline
post #2 of 16 Old 08-28-2009, 07:56 PM
honest bob's Avatar
I don't know how far you mean by "long" but could you stop now and then and just lay the bike on it's right side and brush the dirt off? I know this sounds drastic to people who don't face drastic conditions, but it would take me an hour to tell you what it takes to keep a small aircraft flying under like conditions.
honest bob is offline
post #3 of 16 Old 08-28-2009, 08:02 PM Thread Starter
800 km of continuos dirt road
dustmite is offline
post #4 of 16 Old 08-28-2009, 08:53 PM
Dust doesn't build up on a moving object. Mud will (dries to dirt). Wash the durned thing once in awhile.
Kindest regards,
-Will
willtill is offline
post #5 of 16 Old 08-28-2009, 11:22 PM
silverstrom's Avatar
Throw a small brush in your luggage and use it every time you fill up with gas. It will only take a minute to clean the wheels and should prevent an excessive build up.
I live on a gravel road and I'm always cleaning dust off the rear wheel. If I do more than 50 km of dirt it really starts to pile up on the rim. It's easy to clean off when it's dry. If it gets wet, well then it's pain in the ass.
SS
DL650K7
1985 RZ500
1986 NS400R HRC
1987 RG250
1987 TZR 250
1988 RGV 250
1989 RZ 350 F2
1990 RZ 350 N2
silverstrom is offline
post #6 of 16 Old 08-29-2009, 10:17 AM
honest bob's Avatar
Kindest regards,
-Will
Dust does build up on a moving object that can trap it, that is why the wheels are designed differently for a true dirt bike. The wheel cross section is more U shaped and it has lots of small spokes instead of a big hollow hub and 3 hollow spokes, and a nearly flat cross section rim.
dustmite 800 km of continuos dirt road
Any way you could strap an "air pig" on the back and use compressed air to assist in the dirt removal. It could then be recharged at the filling stations.
post #7 of 16 Old 08-29-2009, 10:22 AM
V-Tom's Avatar
If the dust is sitting on the surface of the rim (as opposed to inside the "spokes",) then a good layer of wax on the rim might help reduce how much the dust sticks. The was might not eliminate the problem, but it could slow it down and make removing the build up a bit easier. The problem is that the chain lube might still make the wheel sticky regardless of the wax (perhaps a teflon lube would help as well.)
..Tom
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is offline
post #8 of 16 Old 08-29-2009, 10:43 AM Thread Starter
thanks for all u'r replies, I will in future take a small brush in my toolkit to clean the rear wheel. It is really very irritating when u do long trips on dirt roads and u must stop all the time to clean the wheel when u'r fellow bikers takes a brake. Otherwise it is a brilliant bike, performance wise and in the handling department.
dustmite is offline
post #9 of 16 Old 08-29-2009, 11:54 AM
honest bob's Avatar
dustmite; If your going to keep the bike for the long haul you can look into changing out the wheels for dirt bike style. (search this site and adventure rider.) You may also want to have a look at your air filter about every 1000km. too! Just my 2 cents.
post #10 of 16 Old 08-29-2009, 01:36 PM
You're right; you've got a point. I was thinking of spoked wheels (don't ask me why) when I replied above in this post.
Kindest regards,
-Will
willtill is offline
