How do you remove the fairing - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 08-23-2009, 06:31 PM Thread Starter
Need to do a little work around steering arm and would like to remove both the left and right fairing..Went around and thought I removed all applicable bolts but would come off..Any suggestions
Cheers
Al
Al Gilliland is offline
post #2 of 3 Old 08-23-2009, 07:32 PM
You need to remove the the black apron piece under the front and then undo the screw holding the side panel, then slide the panel forward and lift off.
RowBust is offline
post #3 of 3 Old 08-23-2009, 09:20 PM
LarryB's Avatar
There's a lot of helpful "how-to"s in the Maintenance section. Like this one: https://www.stromtrooper.com/showthread.php?t=26560
I believe the procedure is about the same for a 650.
[I]If you're not moving forward, you're probably in somebody's way![/I]
Current ride:
2006 Yamaha FJR1300AE, Cerulean Silver
2005 Suzuki DL1000, blue - sold
LarryB is offline
