Anyone installed a car horn as a replacement - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 08-23-2009, 06:03 PM Thread Starter
Hi everyone
Proud owner of a 650 wee as of 2 days ago..Burnt orange with full luggage pack and ABS.
On my old bike I installed a Fiamm car horn in place of my motorcycle horn..Worked very well. I wanted to do the same today but all I got was a popping sound when I turn on the ignition and pressed the horn button. Switched leads and the same..Grounded the horn to the frame..Same again
You can hear the diaphragm popping but no sounds
Any thoughts
Cheers
Al
Al Gilliland is offline
post #2 of 5 Old 08-23-2009, 06:14 PM
LarryB's Avatar
Search the forum for "stebel" and you'll find lots of information about installing horns. 3 quick hints:
1. Don't ever ground to the frame. Just don't do it.
2. You need to use a relay, as the amperage required by a real horn will burn out your horn button.
3. It's a very common upgrade. It's not that hard to make it work right.
[I]If you're not moving forward, you're probably in somebody's way![/I]
Current ride:
2006 Yamaha FJR1300AE, Cerulean Silver
2005 Suzuki DL1000, blue - sold
LarryB is offline
post #3 of 5 Old 08-23-2009, 09:36 PM
AppGap's Avatar
Did you try turning the adjustment screw on the horn?
04 Wee with all kinds of excess crap..
AppGap is offline
post #4 of 5 Old 08-23-2009, 09:38 PM
Some horns like to be rubber mounted, if you mount them too rigidly thay can't vibrate, and the initial "pop" is all you'll get. +1 on using a relay also, most horns draw a few amps.
Pirate650
2007 ABS Wee-Strom "The Silver Surfer"
2003 Kawasaki Concours "Mabel, the Flying Kaw"
Pirate650 is offline
post #5 of 5 Old 08-23-2009, 09:38 PM
What Kinda Bike Is That?
Black Lab's Avatar
I have installed two Fiamms. One on either side of the motor.
Black Lab is offline
