Epiphany about handling - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 134 Old 08-15-2009, 02:24 PM Thread Starter
Somebody at the DL650 Yahoo group wrote about the fairing being involved in high speed instability of our bikes. That lit a light inside my head. I'm copying my post on the subject here.
> At 01:56 PM 8/14/2009, Bryan Whitton wrote:
>>I have been building race bikes for decades and I have never seen a bike
>>become more stable by reducing the trail which sliding the fork tubes up
>>into the triple clamp does. As far as raising the back end. The effect on
>>the front end is the same; you are reducing the trail and making the
>>handling faster and/or less stable. If you lower the front and raise the
>>back you are making it even worse. This is why road race machines are
>>required to have fork dampers; they are basically unstable under certain
>>conditions. Steep rake and short trail numbers make them so.
>>Why would you expect the DL to become more stable by doing this?
I could have written exactly the same thing. All that is true and something we need to understand so I'm not trimming any of it. I like the idea of the fairing being involved. In fact, it may be the most important idea regarding V-Strom stability I've ever read and I've never seen it brought up before. I had a Yamaha XS1100E with a Vetter Windjammer that could lift the front end so much at speed that going much over 100mph would lose all steering input.
The talk about weight distribution needs to be addressed though. Raising and lowering the front with respect to the rear has very little effect on weight distribution. It has a big effect on rake, trail and the angle of attack of the fairing through the air. I recently went from 19mm lowering at both ends to 15mm down in front and stock in back. The former felt better than stock and the latter a lot better at normal road speeds.
I had my only crash involving injury in a quarter million miles of riding on a 2005 DL650 with stock suspension settings when it went into a tank slapper at an indicated 119mph. I've always attributed that to the aerodynamics and weight distribution of a tall windshield and three pieces of luggage. Now I'm thinking the fairing was also involved.
It appears the best way to set up our bikes for most conditions is the drop the front end 5-15mm with respect to the rear. Lowering the front seems to be one good way to do that. It also clamps the fork tubes lower to reduce front end flex. A fork brace will help too. Raising the rear won't do that but will change the fairing angle. Be aware that change of fairing angle that feels so nice at most of the speeds we ride will give the bike an even more unstable geometry at high speeds due to rake and trail reduction.
I've touted the benefits of a Scotts steering stabilizer ever since I put one on after that accident. I've also quit riding over 100mph. I used to do it once every long trip out west to see how fast the bike would go when on a straight run of Interstate with no cars or overpasses in sight. Some results were flying the front end of the Yamaha, breaking a rotor wire on a BMW R90S, breaking or loosening final drive fasteners in the same Beemer and crashing a V-Strom. It isn't worth the risk. Do lower the front a bit, DO add a Scotts and keep the speeds reasonable. Our bikes are not sport bikes. The frame and suspension are designed for handling rough surfaces without bottoming out, not for high speeds on pavement. The fairing is designed for upright rider protection, not for lowering the CD for a crouched rider.
post #2 of 134 Old 08-15-2009, 02:36 PM
2mstone's Avatar
Nice read Pat, thanks for taking the time to post it. One question, with the front lower is the bike still neutral when accelerating in (or out of) a corner?
"Tombstone"
S-10
My Alaskan Adventure
http://2mbstonestravels.blogspot.com/2015/04/alaska-or-bust.html
2mstone is offline
post #3 of 134 Old 08-15-2009, 02:42 PM Thread Starter
The steeper rake and shorter trail make the bike more agile at lower speeds but more unstable at higher speeds. You'll probably like the lower front for cornering.
post #4 of 134 Old 08-15-2009, 03:28 PM
I want my bike as tall as possible so I have never lowered the forks (by raising then in the triples) but I have always thought such small changes results in small effect in handlinfg. I know the effects are real, just tiny.
Has anyone actually measured the difference in rake/trail by raising fork tubes 5-15mm? I'm no mathematical genius but it will make only a very tiny difference. I imagine you could feel the difference, but is it really a dramatic change?
I'd like to opine that the stock DL1000 is quite a competent handler right from the showroom, and is a bike able to change lines in a curve with the best of them. It may not win any roadrace championships, but it is an excellent handler in the real world, and strikes a good balance in being able to handle well in near every condition you are likely to find, this side of serious offroading.
I rub the edges off my tires every chance I get and the confidence level on my Vee is very high. I set it up for sport touring and use a KLR650 for severe trails. What a great combination of abilities--I feel like I've never been so well-mounted in my life. It gives me a new outlook on motorcycling. I think I am a more enthusiastic rider in my advanced age than when I was a kid.
biggyfries is offline
post #5 of 134 Old 08-15-2009, 03:33 PM Thread Starter
Lowering the front a bit is a very easy and free modification. Why don't you try it and see if you notice a difference. That's what counts. I tried it and it makes a noticeable difference to me. Just keep the speeds reasonable if you don't have a steering stabilizer.
post #6 of 134 Old 08-15-2009, 03:37 PM
Cowboys aint easy to love
dancer's Avatar
Short version: Why did you choose 15mm to lower your front?
Long version: What was the method or criterion that caused you to select 15mm as the optimum change in front end height?
Followup question: Was your weight or physical profile a factor in your choice?
Stromless
'97 Honda Valkyrie
I believe in ... gravity!
"Everyone brings something to the party."
- Snoopy
dancer is offline
post #7 of 134 Old 08-15-2009, 03:47 PM
V-Tom's Avatar
Hi Pat,
Interesting comments! I have not doubt the fairing, in particular the part under the cowling/above the radiator has a detrimental effect at high speed stability. The part I mention looks like it is designed to provide lift at higher speeds. Has anyone tried a naked strom at speed?
As far as geometry: What is the rake and trail for a sport bike? What is it for a Dirt Bike? How does the Strom compare? With stock settings, how does stability compare at high speeds with the sport bike, trail bike and Stroms?
..Tom
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is offline
post #8 of 134 Old 08-15-2009, 04:19 PM
Warhammer's Avatar
Stock numbers for a few Suzukis:
DL1000
Rake: 26.5 degrees
Trail: 110.6mm
DL650
Rake: 26.5 degrees
Trail: 110mm
GSX-R1000
Rake: 23.8 degrees
Trail: 98mm
Hayabusa
Rake: 24 degrees
Trail: 97 mm
Boulevard M109
Rake: 31.25 degrees
Trail: 111.76
Boulevard C50
Rake: 33.20 degrees
Trail: 141mm
Bandit 1250
Rake: 25.2 degrees
Trail: 104mm
SV650
Rake: 25.0 degrees
Trail: 100mm
DR650
Rake: 28 degrees
Trail: 105mm
DR-Z400
Rake: 27.4 degrees
Trail: 109mm
Warhammer is offline
post #9 of 134 Old 08-15-2009, 05:13 PM
I always read your posts with interest, because you have so much knowledge about our bikes. I have appreciated your information and have learned a great deal from your posts. However my advice to MOST casual riders is leave the suspension alone. The bike is well set up for most riding conditions that the average rider will incur. Neither the Wee nor the Vee is designed to be ridden at 119 miles an hour. I feel very uncomfortable at speeds approaching 100 mph on my DL, it just does not feel stable.
My advice to anyone that wants to ride a bike at those speeds is buy a bike designed and set up for it. 100mph on a Gixxer or R1 is comfortable and predicitable, or any bike in that category. But I really don't feel that our suspension, brakes, frame etc. is designed for excessive speed. Maybe that type of speed for our bikes is asking too much without some major attention, and modification to the bike.
Safe riding.
Fredeich is offline
post #10 of 134 Old 08-15-2009, 05:26 PM Thread Starter
I learned that lesson the hard way and am on the same page. Except for the bad habit I used to have of seeing how fast the bike could go one time on each long trip, I ride at the speed limit. It will be fine if I never do 100 again. Some readers here will continue to do high speeds though so I threw in the warning that anybody feeling the need at least have a steering stabilizer installed. At sensible speeds, I find dropping the front a good change. I believe Suzuki set up more rake and trail in the stock bike just to make things safer a 100mph or so. They also limited the top speed the Vee will go unrestricted to little more than the Wee can achieve. Our bikes are not designed for more speed than they can handle stock. They are set up as dual sports, not pure sport bikes with more aerodynamic fairings, crouched riding position and less suspension travel.
