A little help with up/back risers please? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 08-12-2009, 04:31 PM Thread Starter
Hey all,
I just purchased a Sargent seat for my K9 ABS Wee and so far it's great BUT...now I am a little higher and farther back and my once bent elbows are pretty much straight now. I'm thinking some up/back risers would do the trick and make for a more comfortable riding position. Has anyone installed them on their ABS Vee/Wee? I understand that I will have to install a new front brake line so I guess I have three ??'s:
1) Which one should I get? I've seen Rox/SW Motech, etc. Some are staticly positioned and some models are "infinitely" adjustable.
2) What kind of brake line should I get? Braided, etc? I'm assuming that I just treat the line replacement like a car line (disconnect at lower end, allow to drain, disconnect top end, replace, bleed/refill fluid?)
3) Do any of the other lines bind (clutch, throttle, electrics)? I'm thinking 1" up 1" back but I've seen even longer.
I know this is a simple thing but I'm just confused by all of the choices !!
rccg94 is offline
post #2 of 9 Old 08-13-2009, 12:23 AM
vegashotwheeler's Avatar
Send a message via AIM to vegashotwheeler
I like the powermadd risers but dont know about what is needed in the ABS models.
Mike
2007 Blue DL650 V-Strom - running out of farkle's to do so bought the VEE
2006 SILVER DL1000 - Running out of Farkles also!!!
2017 EX300 Kawasaki Ninja
Las Vegas, NV
vegashotwheeler is offline
post #3 of 9 Old 08-13-2009, 04:25 PM
lectric's Avatar
risers
I installed the GenMar risers on my non ABS K8. No mods needed. they are static as far as position. I cannot say for sure about the ABS models, but remember reading somewhere here the lines are a bit shorter and may need be replaced. Give Blair at SVracing a shout I am sure he can advise you about the lines and he has a selection to suit your needs. His service and knowledge is outstanding. hope this helps.
lectric is offline
post #4 of 9 Old 08-13-2009, 11:14 PM
xjstrom's Avatar
x2 for the powermadd! Minor tweaks to get extra wiring length but easily done. I have a thread with some pics here somewhere. Price is much better than other options which is very important as I'm Dutch!
[COLOR="DimGray"]Silver K7 Wee[/COLOR]
Silver Strom Club #24
'[COLOR="Red"]99 Jeep Ckerokee (XJ)[/COLOR]
><> IV Men
xjstrom is offline
post #5 of 9 Old 08-14-2009, 08:30 AM
Jimm's Avatar
SW Motech
I have a set of SW Motech up and backs from my previous Vee. I presently have an 09 Wee abs and I can confirm that the front brake line is too short to allow these risers to be used as is. I'm at the age where I have started to pick my battles (probably should have done this years ago). I'll revisit the riser thing when (and if) I get my head around front brake mods.
[FONT="Book Antiqua"]The Power of accurate observation is commonly called cynicism by those who haven't got it.
-George Bernard Shaw
[/FONT]
09 Wee ABS Silver (the other colour)
Lots o other bikes over the years
Jimm is offline
post #6 of 9 Old 08-14-2009, 11:29 PM
Spork Rider's Avatar
ROX
Everytime this question comes up, I suggest the ROX risers. They are a better design from the standpoint of versatility and multiple positions. They are very well made, very strong, and a little cheaper than the gen-mar (which is a very robust but static design).
Being able to experiment with different positions is great.
Also, if you plan to spend time offroad, adjusting them way forward and up makes for a sweet bar location for standing up. The 3 minutes it takes is worth it - I keep a 6mm allen wrench in my tank bag. Also a 8mmx10mm combo wrench to adjust my levers. Invest a little time the first time, and it's quick every time after.
You may or may not need to get new brake lines. I would either way...braided steel makes a big difference.
[FONT=Tahoma][B]07' DL650 [/B][/FONT]
[B][FONT=Tahoma][I]It doesn't stab worth a crap, and the milk dribbles out, but otherwise it works great...[/I][/FONT][/B][B][FONT=Tahoma] [/FONT][/B]
[FONT=Tahoma][B]-Drew[/B][/FONT]
Spork Rider is offline
post #7 of 9 Old 08-15-2009, 12:02 AM Thread Starter
Thanks guys that's the exact info I was looking for. Pretty much what I expected on this forum - it's great. I'll shoot Blair a message about the line.
Spork - I think I'm on the same page about the rox and I will definitely take your advice on the adjustment for standing, I can see where the time would be well spent.
rccg94 is offline
post #8 of 9 Old 08-15-2009, 12:18 AM
mojoman's Avatar
I think the adjustable Rox Rock!
mojoman is offline
post #9 of 9 Old 08-15-2009, 12:20 AM
Had Rox, went to Powermadds adjustable 10 bucks cheaper and one piece so alignment is not an issue.
Mike
Las Vegas, NV
