Rear Axle Dimensions - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 08-10-2009, 01:23 PM Thread Starter
Hello,
I did a lot of searching (to no avail) prior to sending this thread. I have an 08 DL1000 and am considering having a rear axle machined for modifications. Does anyone here have the dimensions of the rear axle? Thread size, Axle diameter, perhaps the inside diameter of the bearings.
Thanks in advance.
KB
kbaston1 is offline
post #2 of 3 Old 08-10-2009, 03:28 PM
16171
What modifications are you planning?
Just curious...
BTD.
post #3 of 3 Old 08-11-2009, 12:22 AM
The rear wheel bearings are #6204 20x47x14mm. The axle is something like 19.87mm. I never measured the length tho.
I think I read somewhere that axles are hard coated.
What are you planning? I did the 5.5" rear wheel conversion and reused the stock axle.
Mountaintime is offline
Tags
dimensions , rear axle
