14 k 1st year - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 08-07-2009, 09:16 PM Thread Starter
Exclamation 14 k 1st year
It's me, it's me it's Eddie. First year on V. 14 K. No problems as of yet, other than dying at stop signs, probably gonna try to raise the idle a tad to see if that helps. May be let the stealership have a crack at it at valve check. Also went to the Conti Road Attack. Lots smoother and responsive. Darn I love this bike
eddiemurphydyte1 is offline
post #2 of 4 Old 08-08-2009, 10:40 AM
Send a message via AIM to Subicon
I've had mine for almost two years and I've only got 8300 so far. I haven't had any issues, but I will need a new rear tire pretty soon.
2008 V-Strom 650 - SOLD
Flat Black Club Member #4
"If you're not weird, then what's wrong with you?"
Subicon is offline
post #3 of 4 Old 08-08-2009, 10:54 AM
14K is a good start. Do get the valve clearances checked. The poll at https://www.stromtrooper.com/forums/s...ad.php?t=43389 indicates the great majority of DL1000s need an adjustment at first check as do almost half of DL650s. Raising the idle of a DL1000 to the book minimum 1100-1200rpm is a typical cure for stalling at idle.
post #4 of 4 Old 08-08-2009, 04:52 PM
Sgt. BawlSaq's Avatar
Yep, they'll be changing till somewhere around 25-30,000 miles.
Sgt. BawlSaq is offline
