Difference between a manometer and a vacuum gauge? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 08-02-2009, 07:36 PM Thread Starter
Quehele's Avatar
It seems to me that a TB sync could be performed with a vacuum gauge. Am I wrong? If I'm right, what's the benefit of a manometer?
Thanks.
Jim
Wife's '09 DL-650: OEM hand guards - DL-1000 lower cowel - 16t counter sprocket - Givi windscreen - Air box mod w/ K&N air filter - GIPro gear indicator w/ ATRE - integrated comm system.
My '09 DL-1000: Air box mod w/ K&N air filter - GIPro gear indicator w/ ATRE - integrated comm system - Givi windscreen.
Quehele is offline
post #2 of 4 Old 08-02-2009, 07:41 PM
Warhammer's Avatar
One tells you how manly you are , the other tells you how much you suck!
Warhammer is offline
post #3 of 4 Old 08-02-2009, 08:04 PM
SCraig's Avatar
You can use a vacuum gauge as long as you have two of them and they are balanced to read the same. The goal is to have both throttle bodies with the SAME vacuum. A differential manometer does that by pulling vacuum on both sides of the tube. The side with the higher vacuum will have a higher column of fluid. I use a Motion Pro SyncPro and it isn't differential. All four columns are individual gauges.
Scott Craig - Nashville, TN
SCraig is offline
post #4 of 4 Old 08-03-2009, 01:03 AM
stevet's Avatar
Here's how to build a manometer for dirt cheap. I used auto. tranny fluid because it's red and easy to see, and doesn't bounce around so easily as water. If using water, put some food color in the water to aide seeing the water level. Slow and a bit of a pain to get the tubing filled with the fluid, though, but once it's built, it's done.
http://www.obairlann.net/reaper/moto...manometer.html
Steve.
Twin Cities, MN, USA
-Me, Steve T.
stevet is offline
