Foggy headlight - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 11-18-2019, 03:13 PM Thread Starter
Supertex's Avatar
Foggy headlight
Hi guys.
I discovered today I get foggy headlight while is raining outside. I never noticed before.
Do you have it too or I need to go to the dealer ?
File Type: jpg DB34B92B-0CB2-47B1-BDB7-A456619C1F7F_1574104173871.jpg (337.8 KB, 14 views)
File Type: jpeg 154F9388-5E62-42A0-B55E-9E1ECFFC2F46_1574104210576.jpeg (90.3 KB, 13 views)
Supertex is offline
post #2 of 6 Old 11-19-2019, 05:57 PM
Most likely ambient air/moisture getting inside. It's suppose to be sealed so that doesn't happen. If there are no rock chips nor damage, it could be warrantied.
2007 DL 650 with assorted upgrades
Solo is offline
post #3 of 6 Old 11-21-2019, 04:11 PM Thread Starter
Supertex's Avatar
Thank you. Headlight will be indeed replaced under warranty
Supertex is offline
post #4 of 6 Old 11-24-2019, 11:19 PM
bighammer's Avatar
I wonder if the bulb socket isn't properly seated.
2018 Flee-Strom 1000XT
bighammer is offline
post #5 of 6 Old 11-24-2019, 11:23 PM
+1 on bulb socket. I would checked it first.
Rick123 is offline
post #6 of 6 Old 11-24-2019, 11:39 PM
I get a small amount occasionally and just put it down to atmospheric moisture getting in through the bulb socket, which I doubt would ever have 100% seal.
I haven't looked at it but if it's like my DR there could be an opening at the bottom of the cover to let it breathe.
portly is offline
