Take off the back tire, you can actually see the tensioner!
My previous bike was a Gen1 Wee (2007 with ABS) and I found that with a really looooong extension (~4ft) there is a clean, straight shot to the tensioner bolt (i.e. no swivel connector needed) so the socket wrench extends past the rear tire. So it is possible to reach it without pulling the tire and no swivel even on an ABS model. However, I did have to borrow some socket extensions from my neighbor. My current bike is a Gen2 Wee (2014 with ABS) and the aim or angle to the tensioner bolt for a clean shot is different. With about 2-3ft of extensions the socket wrench exits just under the swingarm near the rear caliper. Again no removing the tire or using a swivel but it was up on the center stand. I don't know if this applies to the Gen3 bikes but I suspect it would work.
In either case, the biggest pain of removing the rear tensioner bolt is getting the threads started against the spring without crossing up the threads. It is so hard to reach and get the threads started either by hand or with 3-4ft of socket extensions. So what I did here was that I only backed off the bolt 10 full turns without removing it completely. On my K7 I could count full turns because the socket wrench extended past the rear tire but on my L4 I counted 40 1/4 turns because the socket wrench would not do full turns due to interference with the swingarm and exhaust but achieved the same result. Backing off the bolt released enough pressure on the spring that I was able to release the pawl mechanism to loosen the cam chain to free the cams with the bolt in place. Buttoning up was easy because the bolt was already started in the threads.
Next Up: ?
