Stuck fork oil seal - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 2 Post By MotoN8
post #1 of 8 Old 10-09-2019, 08:25 PM Thread Starter
MotoN8's Avatar
Stuck fork oil seal
Hey all,
Rebuilding my forks again. The coastal weather has rotted the inner tubes and I havenít been cleaning them up like I should. So there go the seals.
Anyway, it seems the lower bushing has wedged itís self between the fork tube and upper bushing. The slide hammer method just drives the wedge tighter and compresses the seal. I tried freeing up the seal by going around the outer edge with a small pick and heating the crap out of the outer tube with a heat gun. Then I fastened it to my work bench and secured the bench to the wall to hold down. Yanked like hell on it and nothing. It just gets stuck at full extension and I have to beat it back in to give it another yank. I did this about 10 times while heating it in between yanks. It wonít budge.
Any suggestions?
MotoN8 is offline
post #2 of 8 Old 10-09-2019, 08:56 PM
Some light reading for you. Sorry I can't be of more assistance, just remember reading the following some time back...
https://www.stromtrooper.com/v-strom...k-tubes-2.html
gdrew is offline
post #3 of 8 Old 10-09-2019, 11:22 PM
BC Rider's Avatar
As in the link above I was able to get the seal out by using the suggested hydraulic method. PB Blaster overnight and then wrapped the top of the outer fork tube with a rag and slowly poured boiling water on it till it was too hot to touch. After a few slide hammers it started to move and came apart. One of the bushings was a different color from the other three. I think the dealer (Honda) used an oddball bushing when they did the forks for me.
13 DL650 Current ride
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is online now
post #4 of 8 Old 10-11-2019, 07:35 PM Thread Starter
MotoN8's Avatar
Thank you. I wasnít able to read this in the link. Just something about somewhere to stay...I had considered using PB blaster but wasnít sure if it would cause damage to internals. Glad to know it worked! Were you using the expansion of hot water, or was it just for the heat? Did you seal the hot water inside? If so, I guess Iíd need to plug the bottom hole or reinstall the damper. Thanks again!
MotoN8 is offline
post #5 of 8 Old 10-12-2019, 02:06 PM
BC Rider's Avatar
The complete thread is here. https://www.stromtrooper.com/v-strom...ork-tubes.html The hot water was applied to the outside to heat the top of the outer fork tube up and expand it to loosen the outer bushing. My thought was that the inner fork tube would keep the bushing cool while the aluminum outer would expand. To get the seal out I filled the fork with oil and then pressed it with a jig. (see pics in thread) With the retainer removed the only thing that can move is the seal. Be careful not to shower yourself with oil. I did have to put the damper back in so the bottom bolt and washer could screw tight and seal in the pressure. Didn't torque it tight just enough to seal. Lots more good suggestions from members in the thread.
80 CX500D
77 XS360
78 XS750
76 CB360T
post #6 of 8 Old 10-12-2019, 08:22 PM Thread Starter
MotoN8's Avatar
Hey BC rider. Thanks for all the info. The hydraulic method worked brilliantly. I sealed the bottom, filled the fork full of oil with it extended about an inch, then installed the top cap. I made a jig out of a 4x4 with small bore in the bottom so not to damage the top cap, and put a floor jack under the bottom tube. Fastened the top jig to the wall and compressed the fork till the seal started popping up. Turned the fork upside down and the seal fell out.
Now Iíve discovered the real problem. The upper bushing is stuck and the slide hammer method wonít pull it out. Probably itís the lower bush flaring out the the upper bush and jamming it tight. Iíve got it soaking in PB blaster and will try again tomorrow. Iíll dig around and see if thereís any more info on stuck bushing removal.
MotoN8 is offline
post #7 of 8 Old 10-15-2019, 06:59 PM Thread Starter
MotoN8's Avatar
Update...I took the fork to a local suspension guy. He had the bushing out 20 minutes later and cost $20. Lesson learned
BC Rider and gdrew like this.
MotoN8 is offline
post #8 of 8 Old 10-16-2019, 12:15 AM
BC Rider's Avatar
Excellent price to have a problem solved. If it took him twenty minutes it would have taken me ????????
80 CX500D
77 XS360
78 XS750
76 CB360T
