Tire valve stem broke off - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 29Likes
post #11 of 28 Old 09-10-2019, 08:46 PM
I had aluminum 90 degree stems. I was concerned one would get damaged by a rock or something so I replaced them with the standard rubber 412's again. That's when I noticed the corrosion between the aluminum and steel wheel.
Cryoman is offline
post #12 of 28 Old 09-10-2019, 09:00 PM
Rolex's Avatar
Originally Posted by Nicad View Post
Anyone know of a good metal one for our cast wheels? I have air pressure sensors on mine and they say that metal is suggested as opposed to rubber.
Nicad Garmin are the only brand I know of that askes for steel stems, all other brands are happy for you to use rubber stems.
I put a number of different brands on the scales and they all weigh about the same.
I have been using stem type TPMS for many many years and have never had a rubber stem fail, the stems on my trailer would be well over 10 years old.
With my bikes I change my stems with every tire change, I would do this even if I was not using a TPMS.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #13 of 28 Old 09-10-2019, 09:39 PM
STCorndog's Avatar
I had a rubber one fail on my Road King. It had a goofy skull head for a cap that my father put on it. Front tire went flat at 60 mph. It was an interesting ride to the side of the road and a trailer trip home.
I buy the short rubber ones in bulk and put a new one on every tire or two. Never cared for the angled ones, since they can twist at speed. That said, never heard of an angled one failing either.
STCorndog is offline
post #14 of 28 Old 09-10-2019, 10:53 PM
p38arover's Avatar
This might be of value if you have a problem out and about.
On the way to the V-Strom Gathering in 2011, AstroBob had a valve stem issue:
Originally Posted by p38arover View Post
Bob also had problems on the Thursday between Wee Jasper and Tumut when something split his front valve stem and caused the sudden loss of air in the tyre.
Fortunately, three Telstra techs came along and one of them thought of a solution. He took a piece of heatshrink tubing that had a heat activated glue inside it and slid that over the valve stem. He shrunk it with a gas flame and Bob inflated the tyre to about 20psi. That got Bob into Tumut. The tyre was still holding air the next morning when Bob took the bike to a tyre shop.
For those not in Oz, Telstra is the biggest telco in Australia.
pj9cos likes this.
Ron B. VK2OTC
2007 Yamaha XJR1300
RIP Bucko
1979-2008 - Riding on forever
p38arover is offline
post #15 of 28 Old 09-11-2019, 12:18 AM
I have a Cyclops TPMS and they call for Metal stems. They used to say it was OK to use rubber, but not now..... I suppose to cover your Assets you should err on the side of not being sued. I think I like the outside install system the best of those I have seen here. Just rubber contact on the rim so no corrosion. Would make total sense in any repair kit. Nice and short to give room getting the pressure gauge on the valve.
Bob S 2017 Vstrom 650 Base model (White)
2018 Yamaha WR250R
1984 Honda VF 500f Maybe more coming up from the lower list
Previous loves:
2017 Yamaha YZ250X
1982 Yamaha 650 Seca 1978 Honda CB550
1974 Suzuki GT380 1977 Yamaha RD400
1973 Can Am MX1 125 (Bought while Mom was out of town)
Nicad is offline
post #16 of 28 Old 09-11-2019, 12:24 AM Thread Starter
Spec's Avatar
Originally Posted by locoblanco View Post
This is similar to the "oil drain plug washer" argument.
A pair of tires average cost is $300. A pair of valve stems cost 79 cents. Do you want a $300 job to fail because of a 79 cent part?
I change them every time. Overkill? Certianly, but I'm not going to have a problem because of being too cheap to spend an extra 79 cents on my $300 set of tires.
Hah I don't change the oil drain plug washer either!
Probably jinxed myself now
muleskinner likes this.
Spec is offline
post #17 of 28 Old 09-11-2019, 07:17 AM
bighammer's Avatar
In a lifetime of oil changes, I've replaced one; copper that was getting thin and jagged.
HokiesRWee and Spec like this.
2018 Flee-Strom 1000XT
bighammer is offline
post #18 of 28 Old 09-11-2019, 08:48 AM
D.T.'s Avatar
Buy a new one and replace it!
Lube it up a bit and use that special puller and pull the new one in!
Probably on Youtube somewhere.
Spec likes this.
D.T. is offline
post #19 of 28 Old 09-11-2019, 09:28 AM
PerazziMx14's Avatar
Originally Posted by Big Boy View Post
I've used the 90 metal valve stems in the past. They work great and allow easy air ups.
If you turn the 90 degree stem so its inline w/ the wheel it'll make it even easier to check the air pressure plus it does not stick out past the spokes to get hung up on stuff and you can read the pressure from either side of the wheel.
PerazziMx14 is offline
post #20 of 28 Old 09-11-2019, 10:00 AM
bwringer's Avatar
Exactly.
I replace the rubber valve stems with every tire change, and I will not use the aluminum replacements; they're too vulnerable. I can see a slight case for using high quality metal 90 degree stems on a sportbike (no fleaBay cheapies) because access can be a pain with 17" wheels and giant rotors. However, these things have absolutely no business on an "adventure" bike, and in any case access the valve stem is not an issue at all on a V-Strom.
I know the metal valve stems have their fans, who I have now offended greatly. So let me ask: when is the last time you replaced the seal or o-ring? Can you even get these parts?
Spec likes this.
bwringer is offline
