Gas tank vapors - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 11 Old 09-05-2019, 08:44 AM Thread Starter
Gas tank vapors
After parking my 2014 DL650 inside garage after a 30 min ride, outside temp in mid 80's Farenheit, I noticed a new noise, hissing like, coming from gas tank cap. Assume it was from gas vapors escaping from tank, 3 bars showing on fuel gauge.
Should I be concerned about the filler cap gasket? Have had other bikes in hot weather and am used to vapor pressure being contained by screw on caps so wonder if what I described above is normal or not.
Thanks in advance,
Mark
mpom is online now
post #2 of 11 Old 09-05-2019, 12:39 PM
I had a 650 scooter that would release pressure from the gas tank with a noise that would make a small boy jealous. rude scooter. thankfully that never happened in a mixed social group. it would sound pretty bogus to say "it wasn't me, it was the scooter"
being as this is as new noise it may well be a gasket or some source of pressure leak.
could you spray wd40 around the gasket and filler and look for bubbles when it makes noise?
RLBranson is offline
post #3 of 11 Old 09-05-2019, 03:53 PM
just light a cigar and relax
offnote is offline
post #4 of 11 Old 09-05-2019, 06:47 PM Thread Starter
I'll take your response to mean "relax, nothing to worry about" rather than a suggestion to blow up my garage 😲
Mark
mpom is online now
post #5 of 11 Old 09-05-2019, 09:13 PM
Rolex's Avatar
It is something you can't stop from happening, there must be a exchange of air between your tank and the outside.
Sometimes it will be sucking and others blowing out.
It is just that you heard it happening, it has always happened.
Some bikes have a canister to collect the fumes
Yes Relax.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #6 of 11 Old 09-05-2019, 10:05 PM Thread Starter
Thanks, gents, glad its a non issue.
Mark
mpom is online now
post #7 of 11 Old 09-05-2019, 10:49 PM
Wife's ninja does it like nobody's business for a wide range of weather. Don't worry about it, it is releasing the pressure. It not releasing it is the real problem lol.
Sent from my SM-G955U using Tapatalk
jackalo626 is offline
post #8 of 11 Old 09-06-2019, 04:18 AM
Gert's Avatar
Have you tried simply opening the gas / fuel cap for a few seconds.Take care when opening the cap under pressure. The tank should have a venting system, that could be blocked / faulty. There is a mod for an older Vee, https://www.stromtrooper.com/dl1000-...nted-hose.html.
RestoRider2017 likes this.
Gert is offline
post #9 of 11 Old 09-06-2019, 06:37 AM
AFAIK, on the DL1000 there is a rubber hose coming from the bottom of the gas tank and going all the way to the bottom of the bike. This is the gas vent - unless you live in California in which case it goes through a charcoal canister under the seat first.
It is extremely easy to pinch this line after having lifted the tank for maintenance. So you might want to check that nothing under the gas tank is pinched.
Gert, RestoRider2017 and RLBranson like this.
BackPacker is online now
post #10 of 11 Old 09-06-2019, 10:30 PM
RestoRider2017's Avatar
Location: Apopka Florida NW of Orlando near a twist in the road and a hill on the horizon...
I have to agree with those saying to check the vent tube for blockage or restriction. Mud can clog the bottom of the vent tube.
Or insect nests. And a pinched tube has to be ruled out by inspection. I've parked my bike in the garage with varying levels of fuel
in the tank and the oder of gas fumes has never been an issue. Even my sons bike is parked in there and between the 2 it never
smells like a strong gas vapor. If it vents to a charcoal canister make sure all the hoses going to the canister are good with no blackage.
It is true that the system must be able to vent fumes to prevent too high a pressure in the gas tank.
2017 DL 650 , Shad 23 bags, Givi crash bars, 32 watt LED aux lights , Goldwing pegs, Metalic silver front fender, Lazer cut aluminum Chain guard, Madstad 20" windshield
light smoke tint , Blu/blk Driven Racing Billet bar ends, Dbl Take adventure mirrors , BeadRider Ceramic bead seat cover,
Stock exhaust for now. Yoshimura 3/4 system simmering on low in the oven.
Avatar image is a custom made Harley Sportster all hand built from junk parts from a retired engineers desk. Took 80 hours to make.
RestoRider2017 is offline
