Uneven tread wear? - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 9Likes
post #11 of 19 Old 11-02-2019, 09:31 PM
shu
shu's Avatar
Originally Posted by foo View Post
These tyres held the pressure up for way more than 12 months of me checking every month or so. At some point one gets complacent, I guess, if nothing changes.
That's impressive. I check my every few days, but it's a habit developed from my other bike (DR650). It has tubed tires and they continually need topping off.
...........shu
shu is offline
post #12 of 19 Old 11-02-2019, 11:03 PM
blaustrom's Avatar
... Next time I'll up the pressure to 36 psi.
Even 36 PSI is still low, maybe not for your tire?? I run 38/42 on Tourance Next/ Tourance and that limits pressure buildup by heat of operation to about 3 PSI.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #13 of 19 Old 11-03-2019, 12:15 AM
Tire pressure sensor kits are about $40 now and that's probably less than the cost of the shortened tire life.
I also run PR4's on notoriously abrasive chip roads and don't see that, so I'll also go with you got that tire REALLY hot at some point.
PeteW is offline
post #14 of 19 Old 11-03-2019, 01:37 AM
slovcan's Avatar
Might be a good idea to check your rear wheel alignment, too. If it is toed to the left from an inaccurate chain adjustment you could see more wear on the right side of the tire.
Going up a couple of lbs on the front can help the tire last longer by slowing down the cupping of the tire. I always set the rear at 40ish (like the 2-up recommendation) even though I never ride 2-up. I usually have some weight in the bags.
Cheers,
Glenn
Anything can happen in Formula 1 and usually does! - Murray Walker
Here - 2002 V-Strom DL1000, 1999 Triumph Trophy 900, 2003 Maxima SE 6-Speed, 1997 Silverado K2500 - 454
Slovakia - 2004 Rover 75 CDT Tourer w/ Tuning Box
Past - 1977 Honda 400/4 Supersport, 1982 Honda CB900 Custom, 1984 Honda V65 Sabre (TWICE), 1996 Kawi GPz1100, 1990 Honda VFR750F
slovcan is offline
post #15 of 19 Old 11-03-2019, 03:11 AM
Gert's Avatar
Often the cause of a slow tire pressure leak, is the valve condition, https://www.stromtrooper.com/general...broke-off.html and https://www.stromtrooper.com/mainten...k-dry-rot.html
Gert is offline
post #16 of 19 Old 11-03-2019, 07:19 AM
My old Beemer would wear the left side of the front tire so much that I had to replace the front as often as the rear. Beemer guys said it was the crown of the road or left turns were longer causing more wear, but.....My Versys was not that severe. I could almost get twice the mileage on the front as opposed to the rear. Some of this has to be weight or factors I can't pretend to understand but I left the BMW crowd with negative feelings about German engineering.
While I really enjoyed the Versys it never made me smile like my new Wee.
Beachbum is offline
post #17 of 19 Old 11-03-2019, 08:03 AM
OydnaR's Avatar
Originally Posted by Big Boy View Post
Here's my SWAG at the problem.
I've seen this due to the 'crown' on the road. In the US it's on the left side of the tire. Since you guys drive 'left' I would expect to see more wear on the right.
not due to crown, simply the fact we drive on right side of road and curves to left are longer than curves to right
this guy explains it better than me
Motorcycle Tire Wear
IBA#9560
Copyright (c) 2019
OydnaR is offline
post #18 of 19 Old 11-03-2019, 09:13 AM
"limits pressure buildup by heat of operation to about 3 PSI."
I had tire pressure monitors on my 800ST BMW. I didn't notice a pressure read out difference from cold to warm tires. It read the 36/40 I ran in the tires unless for some reason, like a flat, it lost air.
i generally check the tire pressure once a week.
post #19 of 19 Old 11-03-2019, 10:33 AM
blaustrom's Avatar
The BMW tpm do compensate for temperature change and report a calculared adjusted pressure.
Tires do warm up and increased temperature does increase pressure, one of the very basic laws of physics. I have garmin tpm's and they show actual pressure.
Blau2 2014 DL1000A
Tags
tire wear uneven
