Inspecting a bike with 50K+ miles and getting it all caught up on everything? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By Nicad
  • 1 Post By notacop
post #1 of 5 Old 08-07-2019, 02:07 AM Thread Starter
talonstrom72's Avatar
I've had my bike a couple years, I bought it used. It has about 53k on it now and I am curious; what do I need to inspect at this point?
I already know about spark plugs, air filter, oil, filter, plug wires, coolant, VALVES, fuel filter. Synchronize throttle bodies.
I'm mainly curious about the axle bearings and anything else that isn't quite so obvious. There may be a post that covers everything, I'm not sure.
Mainly I just want it running as good as I can to prevent a breakdown.
talonstrom72 is offline
post #2 of 5 Old 08-07-2019, 09:13 AM
I think the steering bearing is an important one at this point to have a nice handling Vstrom.
talonstrom72 likes this.
Bob S 2017 Vstrom 650 Base model (White)
2018 Yamaha WR250
1984 Honda VF 500f Maybe more coming up from the lower list
Previous loves:
2017 Yamaha YZ250X
1982 Yamaha 650 Seca 1978 Honda CB550
1974 Suzuki GT380 1977 Yamaha RD400
1973 Can Am MX1 125 (Bought while Mom was out of town)
Nicad is offline
post #3 of 5 Old 08-07-2019, 10:28 AM
Wheel bearings can be checked when you change tires. Stuff like swing arm bearings and the bearings in the shock area could stand a look at.
Depends on how much bad weather you've been riding in.
A friend that does cross country travel had the wheel bearings get bad traveling through the rain storm remnants of some of the hurricanes.
Too bad they use strange nuts on the swing arm and make it more difficult to disassemble. The shock and the linkage isn't difficult to remove.
I need to do mine but I've got a 100K miles. The steering bearings do need attending too.
post #4 of 5 Old 08-12-2019, 04:08 AM
more
Might find the controls work more smoothly if you disassemble and grease the hand and foot lever pivots. Flush the brake and clutch fluid as well.
Jimding is offline
post #5 of 5 Old 08-12-2019, 08:32 AM
D.T.'s Avatar
How about compression? Supposed to be within a few psi of each other. Usually around 190 psi. If it uses oil could be rings or valve guide seals.
Wheel and shock linkage bearings too.
D.T. is online now
