Whirring - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Brockie
post #1 of 3 Old 07-30-2019, 02:15 PM Thread Starter
Whirring
2019 vstrom. Tightened chain resulting in loud whirring from front sprocket and seemingly front wheel. Lossened chain and front sprocket sound went away. I still hear a whirring sound from front wheel when driving or even coasting with clutch held in. Normal tire sound? Bridgestone battle-ax . Bike has only 3000 miles on it mostly on expressway speeds greater 70+ mph. thanks.
Ttom is offline
post #2 of 3 Old 07-30-2019, 02:23 PM
I get a "whirring" sound at around 4500-4600 RPM that sounds like it's coming from the front wheel. Every bike I've owned had some sort of sound like that at various RPM's. My Katana used to do it at 3500RPM. Probably just the various vibration frequencies synchronizing to produce a hum. I don't worry about it.
2015 DL650A, Candy Daring Red (mine)
2017 Honda CB500XA, Candy Rose Red (my wife's)
2015 Honda CBR300R
1982 Suzuki GSX750S Katana
1981 Suzuki GS650GL
1983 Suzuki GS450L
Skinner is offline
post #3 of 3 Old 07-30-2019, 08:05 PM
Brockie's Avatar
I would worry about the front sprocket whir after tightening the chain. You did the right thing to loosen it. There are many threads here advocating running the chain with a little more slack than recommended.
Too tight will put extra load on the chain, sprocket, and countershaft bearings. I always adjust my chain to the maximum allowable slack 1 1/4in. A little more is fine - a little less can accelerate wear.
All tires make some sort of humming noise on sealed road. It becomes more pronounced with the clutch in.
Griff2 likes this.
Brockie is offline
