How to remove handgrip glue - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 07-26-2019, 03:52 PM Thread Starter
Hi, when using one of those super glue for the handgrip, some of it fall on the tank paint and on the plastic the protect the tank. Did not see it when it and now it is hard. What can I use to remove it without doing any damaged. I use paint thinner on the tank and goo gone on the plastic but did not work.
Thanks
Wisedom84 is offline
post #2 of 8 Old 07-26-2019, 05:35 PM
Acetone will break down superglue. So nail polish remover should work.
Plateauplower is offline
post #3 of 8 Old 07-26-2019, 05:44 PM
christophermarkfoster's Avatar
They also make debonders. Careful you don't go through the paint with any solvent.
Chris
1. 2004 DL1000
2. Next bike
3. Next bike
4. Next bike
christophermarkfoster is offline
post #4 of 8 Old 07-26-2019, 07:50 PM
p38arover's Avatar
Paint thinners and acetone will very likely damage the paint.
I can't suggest anything that might work.
Ron B. VK2OTC
2007 Yamaha XJR1300
RIP Bucko
1979-2008 - Riding on forever
p38arover is offline
post #5 of 8 Old 07-26-2019, 07:58 PM
PerazziMx14's Avatar
Nail polish remove is acetone.
Acetone is the best at softening and removing cyanoacrylate adhesives.
PerazziMx14 is offline
post #6 of 8 Old 07-26-2019, 08:41 PM
Whatever solvent you decide to use, try it on a small spot that is not visible on the bike - like a part of the tank that is covered by the plastic pieces but still has the paint you don't want to damage. Scrub away, just like you will do on the drops of glue and see if you damage the painted surface.
You might call the manufacturer (do a google search) and ask them what you can use. Or simply do a google search for solvents for cured crazy glue.
Ratchet is offline
post #7 of 8 Old 07-27-2019, 07:29 PM
eff
eff's Avatar
WD-40
Sent from my Pixel using Tapatalk
2007 V-Strom 650
2004 GasGas EC250
eff is offline
post #8 of 8 Old 07-27-2019, 09:45 PM
I have wet sanded a few places on my bike with an air sander and 2000 grit paper. Then hit it with two levels of polish and then wax. I just got done wet sanding the entire gel coat of my boat so I have a little practice at it.
Chris
1. 2004 DL1000
2. Next bike
3. Next bike
4. Next bike
