can a bad chain make bad sounds? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #1 of 15 Old 07-23-2019, 06:57 PM Thread Starter
I was on a ride when I started to feel some slippage. I stopped and inspected my chain which had substantially loosened up to the point it was dragging on my center stand! (Very dangerous amount of play actually) I had the tools to tighten it up, but from that point, a weird sound started happening. Almost sounded like sloppiness in the transmission. When I got home, I removed the front sprocket cover and noticed a lot of O-rings in the chain lube gunk that built up on the cover. It's an 07 DL650 with 24k miles. This possibly could be the original chain??
I just ordered a new chain and set of sprockets in hopes this will resolve that new noise. Has anyone else experienced this?
craig3x is offline
post #2 of 15 Old 07-23-2019, 07:04 PM
PerazziMx14's Avatar
Yes very easily the stock chain and sprockets at 24,000 miles. With the right care they would have gone many more miles.
New chain and sprockets will go a long way in making things better.
Also inspect the wheel/cush bearings and cush drive rubbers when the wheel is off the bike.
When you put everything back together make sure you align and tension the chain properly.
PerazziMx14 is offline
post #3 of 15 Old 07-24-2019, 10:09 AM
Once you get that new chain and sprockets on and adjusted right, you will think you got a new bike. Keep that chain oiled with gear lube and you should get at least 20k miles out of it.
While you have the wheel off, check the Cush drive
Macdoc likes this.
ehart814 is offline
post #4 of 15 Old 07-24-2019, 10:42 AM
bad chain or sprockets can make all kinda strange noises, along with bad bearing BTW.
offnote is online now
post #5 of 15 Old 07-27-2019, 06:58 AM
Yes make sure to accurately align the chain. I never believed the old saw about the alignment marks may not be accurate but I do now. My chain is not aligned if using those marks, I bought the Motion Pro alignment tool and no more problems.
The rubber cush drive needed replacing after a few years and 40,000 miles also. Was loose to the point of sprocket falling off wheel when removed. It can be shimmed but new OEM wasn't too expensive.
What's the worst that can happen?
ratbikerandy is offline
post #6 of 15 Old 07-29-2019, 01:23 PM Thread Starter
Reporting back. You weren't kidding. Put the new sprockets and chain on and it really does feel like a new bike!!! All strange noises are gone.
craig3x is offline
post #7 of 15 Old 07-29-2019, 01:34 PM
Mucksavage's Avatar
Not to Hi-Jack but what is the criteria for "checking" the cush drive rubber?
'12 Glee, Metallic Fox Orange, '98 DR350, CMA #183680
Mucksavage is offline
post #8 of 15 Old 07-29-2019, 03:53 PM
blaustrom's Avatar
Cush drive: When you turn the rear wheel over and the sprocket carrier falls out it definitely is bad. It should sit tight!
My test is trying to lift the rear wheel (laying flat on the ground) up on the sprocket. If the carrier falls out attempting the lift, need new rubbers or shimming or more shimming.
Gert likes this.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #9 of 15 Old 07-29-2019, 03:55 PM
rear sprocket falling out.
post #10 of 15 Old 07-29-2019, 09:29 PM
Mucksavage's Avatar
Thank you both!
