What's a good bang for buck motorcycle battery? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 25Likes
post #1 of 30 Old 07-22-2019, 05:35 PM Thread Starter
talonstrom72's Avatar
Battery died, unable to recharge. What's a good bang for buck battery? The market it's hard to make sense you got $40 china batteries and you got $200 and everything in between. But who can afford to spend $200 on a battery?
What's the most battery for the least coin, the bang for buck option?
talonstrom72 is offline
post #2 of 30 Old 07-22-2019, 06:20 PM
PerazziMx14's Avatar
I've used $22 garden Everstart U1 tractor batteries from Walmart on several Guzzi's with great success. They are also a direct swap to my zero turn.
A $22 its a tremendous bang for the buck if you ask me.
D.T., notacop, Webfors and 2 others like this.
PerazziMx14 is offline
post #3 of 30 Old 07-22-2019, 06:44 PM
STCorndog's Avatar
The strom battery box is sized where you will need the correct battery dimensions. I would go back with an AGM Yuasa. Enterprise sells a battery with their name on it that is made by Yuasa (exact same case). Either one is around $100.
I go middle of the road. I would not use a lawn mower battery, but I also would not use a Lithium either.
Whatever you use, don't get an old fashion wet cell. If it pukes acid, it will corrode all sorts of important stuff.
Big B, Cryoman and talonstrom72 like this.
STCorndog is offline
post #4 of 30 Old 07-22-2019, 06:53 PM
chicago's Avatar
I had to replace a 6 month old Chinese battery far from home I just go with Yuasa. ymmv.
14 tooth for me
chicago is offline
post #5 of 30 Old 07-22-2019, 06:53 PM
Wally Mart battery lasted over 6 years on my Wee Strom. Didn't realize it came from there after i bought a generic at the auto store and pulled it out. Wally Mart was much less expensive too.
talonstrom72 likes this.
post #6 of 30 Old 07-22-2019, 08:45 PM
WildDoktor's Avatar
Battery died, unable to recharge? Yeah, you need a battery, but...do you know *why* it died? That's what you really need to fix. In fact, if you fix that, you may not need a new battery. (Unlikely, but possible.)
WildDoktor is offline
post #7 of 30 Old 07-22-2019, 09:01 PM
Batteries are somewhat the luck of the draw. I bought a DEKA battery and within a few weeks it would not take or hold a charge. Took it in for a replacement and the second one did the same thing within a couple days. Took it in and got a 3rd and its probably still going.
post #8 of 30 Old 07-22-2019, 10:12 PM
locoblanco's Avatar
Oreillys, (and probably other auto part stores too), sell a fully sealed AGM battery. No need to add acid, ready to install without charging. Has big beefy terminals you can really crank down on when tightening the cables. About $85 last time I checked. Part # ETX12.
Sagebrush and talonstrom72 like this.
locoblanco is offline
post #9 of 30 Old 07-23-2019, 09:40 AM
Unless I simply have to have a battery immediately, I have been going to Battery Mart. Usually have a few to select from. The link is what I throwed in there for my 2012 DL 650. But they have more than about any other source.
Larry33319 likes this.
realshelby is online now
post #10 of 30 Old 07-23-2019, 09:48 AM
Not worth risking a defective cheap battery.
spend the money, get a quality battery and worry free. Know that you won't get stranded while riding. I've gotten cheaper alternative battery that's left me stranded. Ended up paying more.
I would either get a Yuasa or an Odyssey(if they make it for the vstrom).
D.T. and talonstrom72 like this.
2008 Suzuki Vstrom DL650
2013 Yamaha WR250R
2004 BMW R1150RT
2002 Ducati 998 Superbike
2001 BMW R1200C Phoenix/Independent
1982 BMW R100RT
2003 Kawasaki Ninja 250r - Sold
1985 Yamaha FZ-750 - Sold
1984 Kawasaki GPZ-750 - Sold
bmwguy is offline
