Leaking Gas Tank - Fix or Replace? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 11Likes
post #1 of 23 Old 07-20-2019, 08:00 PM Thread Starter
Sage77's Avatar
So I finally had the time to pull my tank off and I found what appears to be the culprit of my gas leak. Looks like it's leaking from the seam.
Does anyone know a good way to fix this or am I looking at having to replace the tank?
Also...what the heck is that red crap??
Thanks y'all!
Regards,
Sage77
*Proud owner of my 5th motorcycle, although it's the only one I still have. We'll get into those stories later....*
Kawasaki 454LTD...
Yamaha FZ600... ;/
Honda CX500...
Honda CBR600... ;/
Suzuki DL650 V Strom K4...
Sage77 is offline
post #2 of 23 Old 07-20-2019, 08:27 PM
I don't know what the red crap is but if that's the outside of the tank what the hell does the inside look like?
I think you will be needing a replacement tank but you may also be able to do a short term repair with some JB Weld or whatever.
STCorndog and Sage77 like this.
gdrew is online now
post #3 of 23 Old 07-21-2019, 12:55 AM
Rolex's Avatar
The red crap is to stop rust I would think.
There are putties on the market that will seal a hole and last a lifetime but a seam can be a hole other problem, the leak can just keep growing over time or it may never grow at all.
Sealing the tank from the inside is a proven fix if you follow the instruction to the letter.
Now the decision is do you have the time, the place and the skills required to seal the tank.
Then you would need to look at the cost, tank sealer and your time verse a replacement tank.
Lets face it that tank has seen better days.....
Sage77 likes this.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #4 of 23 Old 07-21-2019, 04:34 AM
Gert's Avatar
Gert is offline
post #5 of 23 Old 07-21-2019, 08:09 AM
RCinNC's Avatar
I think I'd start out with the cheapest solution: a Tank Weld kit from JB Weld. It's about 12 bucks from Amazon. It's basically just SteelStik two part epoxy putty plus some fiberglass mesh for added strength. If it's leaking along a weld seam, the mesh should help seal it better.
Sage77 likes this.
RCinNC is offline
post #6 of 23 Old 07-22-2019, 01:41 PM Thread Starter
Sage77's Avatar
Thanks y'all for the suggestions. I'm going to get that tank weld to get the leak fixed for now and start looking for a replacement tank. As @Rolex said...that tank has seen better days. lol
Regards,
Sage77
Kawasaki 454LTD...
Yamaha FZ600... ;/
Honda CX500...
Honda CBR600... ;/
Sage77 is offline
post #7 of 23 Old 07-22-2019, 02:43 PM
Boriqua's Avatar
I have had great success with pin hole leaks or small leaks at seams using KBS
Look up kbs-coatings Dot com
Its not the cheapest solution and it is somewhat time and labor intensive but you should never have to think about the tank again. I dont know what a new tank cost but the coating should certainly be cheaper than a new tank .. I am guessing
Sage77 likes this.
Boriqua is offline
post #8 of 23 Old 07-22-2019, 05:50 PM
STCorndog's Avatar
I would look at the inside of the tank also. The tank could be passing debris into the fuel system and take out a lot of expensive parts in the process.
STCorndog is online now
post #9 of 23 Old 07-22-2019, 06:35 PM
dravnx's Avatar
Who is Wendy?
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
miles smiles=bike.
It's simple math.
dravnx is online now
post #10 of 23 Old 07-22-2019, 06:54 PM
PerazziMx14's Avatar
I'd toss that tank in the bin and buy a good used one. There are lots of choices in the $150 to $250 range on the big auction site.
Cryoman and Sage77 like this.
PerazziMx14 is offline
