How do you put the hole in the dash for a charger? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 37Likes
post #1 of 27 Old 07-20-2019, 03:34 PM Thread Starter
talonstrom72's Avatar
I bought a charger from ebay with a built in volt meter.
How do you put the hole in the dash for the charger? Is there a special drill bit?
talonstrom72 is offline
post #2 of 27 Old 07-20-2019, 03:43 PM
nvr2old's Avatar
Hole saw w/ a pilot drill.
Brockie likes this.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #3 of 27 Old 07-20-2019, 03:45 PM
NVDucati's Avatar
They are called "Hole Saws". Used with an electric drill.
Take the plug with you when you go to the store for checking the size. Drill slowly.
Maybe practice on a plastic wastebasket or similar.
Gert and Motorpsychology like this.
Member: AMA
NVDucati is online now
post #4 of 27 Old 07-20-2019, 04:02 PM
PineLaneRider's Avatar
Depending on size a STEP BIT may also work.
sngltrk, Gert, Cryoman and 2 others like this.
PineLaneRider is offline
post #5 of 27 Old 07-20-2019, 04:17 PM
actually it's easy...
Byronw, Slow Eddie, jdfog2 and 9 others like this.
offnote is offline
post #6 of 27 Old 07-20-2019, 04:23 PM
K9 Wee's Avatar
You could also do one of these shelves...room for a couple of accessories.
https://www.adventuretech.biz/auxili...main-page.html
jdfog2, thirdofthree, Gert and 1 others like this.
______________________
2009 Orange DL650
SW Motech Rally Crashbars, Skidplate & Centerstand
Givi e22L Sidecases
Shad 33L Topcase
Wolfman 40L Waterproof Duffel
Givi Tanklock 20L Tankbag
Techiwik Long Underwear
1978 Honda CB550K-Sold
K9 Wee is offline
post #7 of 27 Old 07-20-2019, 05:21 PM
RCinNC's Avatar
I often use Forstner bits when I'm drilling holes in plastic. They make a very sharp, clean hole when the bits are new. If you're making a through hole, the Forstner bits work best if you're able to support the piece you're drilling through with something like a piece of scrap wood under it (but they'll work without it). Make sure you go slow, or the plastic will start to melt and you'll cut a ragged messy hole.
Gert, MrF and Motorpsychology like this.
RCinNC is offline
post #8 of 27 Old 07-20-2019, 05:40 PM
PerazziMx14's Avatar
Holes saws on thin plastic I run in reverse once the pilot is thru.
PerazziMx14 is offline
post #9 of 27 Old 07-20-2019, 05:43 PM
Step drill is by far the best
sngltrk likes this.
Cryoman is offline
post #10 of 27 Old 07-20-2019, 06:01 PM
Dark Angel's Avatar
mmmmm plasma
Seriously though, I'd just use a holesaw and take my time.
Just remember, you can't UN-drill the hole. Be certain it's in the right place.
iamsmiling and PineLaneRider like this.
Dark Angel is offline
