Do you have to remove the gas tank to install charger - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
  • 1 Post By marcham
  • 2 Post By Ratchet
  • 3 Post By Gert
post #1 of 7 Old 07-12-2019, 05:26 AM Thread Starter
talonstrom72's Avatar
Do you have to remove the gas tank to install phone charger, or can you just reach down there and run wires without taking off the tank?
2007 DL650 Non ABS.
talonstrom72 is offline
post #2 of 7 Old 07-12-2019, 05:31 AM
marcham's Avatar
No need to pull the gas tank...
Sent from my SM-T720 using Tapatalk
talonstrom72 likes this.
2015 VSTROM 650 X ABS EXP
marcham is offline
post #3 of 7 Old 07-12-2019, 07:21 AM
I don't understand what pulling the tank might have to do with this. If you are going back to the battery or an aux. fusebox under the seat, you can fish your wires down alongside the frame and then up into the cavity around the steering head. At some point you might need a stiff piece of wire about 18" to 2' long to poke through, but all this is doable without removing any body parts. Go slowly, sheath your wires in loom (plastic tubing or woven tubing) to help protect them against chafe, and zip tie them to the frame out of the way of anything that might get hot.
bobbyvstrom and talonstrom72 like this.
Ratchet is offline
post #4 of 7 Old 07-12-2019, 04:42 PM Thread Starter
Ok thanks, glad to hear it sounds pretty easy.
post #5 of 7 Old 07-12-2019, 10:10 PM
MrF
MrF's Avatar
One of these can help a lot with running wires too:
https://www.amazon.com/TEKTON-7597-3...JST44E10NENPF3
2016 V-Strom 650
MrF is offline
post #6 of 7 Old 07-13-2019, 03:46 AM
Gert's Avatar
Lifting the tank and placing it on its perch, is not difficult, https://www.stromtrooper.com/dl650-d...-gas-tank.html. Lifting the tank to the perch allows you space to ensure that the wiring that you have added, does not touch sharp edges or hot motor. So if it were me, I'd lift the tank to the perch as in post #12 of the attached link. Another link that can help with info on lifting the fuel tank is https://www.vstrom.info/Smf/index.php/topic,7566.0.html.
Gert is offline
post #7 of 7 Old 07-20-2019, 02:10 AM Thread Starter
I will do that.
