Does this ignition problem ring a bell? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 07-12-2019, 04:26 AM Thread Starter
Hi there.
2017 DL 650 bought new, well maintained, with 90,000 km's.
Maybe someone has encountered this already:
Switch on. All displays normal.
Am in Neutral
Clutch pulled in.
Press the button - Nothing happens.
Scratch my head and do it again - Bike starts.
This has already happened twice. I'm guessing it will happen again and eventually will die.
My guess: Either the starter switch or the clutch micro-switch thingy are defective.
Thanks in advance
olgeezer is offline
post #2 of 4 Old 07-12-2019, 05:08 AM
Brockie's Avatar
Possibly a faulty starter switch. Check out this thread: https://blacklabadventures.com/2012/...h-maintenance/ or this video:
Brockie is offline
post #3 of 4 Old 07-12-2019, 05:36 AM Thread Starter
Thanks for the link and video! I'll try that.
olgeezer is offline
post #4 of 4 Old 07-12-2019, 12:47 PM
Stalky Tracker's Avatar
I would also suspect the clutch "micro-switch thingy". When it doesn't start, hold the start button in partially release the clutch lever just a little and pull in again. Sort of a wiggle back and forth. If it then starts, I would suspect the clutch switch is going bad.
When mine started to go, it acted just like yours. Eventually, it took numerous attempts & wiggles to start. At that point jumpering the wires solved the issue until a replacement arrived. Although mine was about 14 years old and had 60,000+ miles on it.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
