Key out DL650 stays runnig - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 3 Post By nvr2old
post #1 of 5 Old 06-29-2019, 12:43 PM Thread Starter
Headlight,dash everything stays on bike keeps running when I turn the key off or lock steering and remove key. Bike is apart to access wiring harnesses unplugged ignition wire no change put in dealer mode got c-42 and c-49. Fuses all good no visible wire damage or burning. Stumped any ideas
laynep is offline
post #2 of 5 Old 06-29-2019, 12:48 PM
nvr2old's Avatar
Ignition switch sound likely.
notacop, Brockie and Cryoman like this.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #3 of 5 Old 06-29-2019, 04:19 PM
blaustrom's Avatar
I remember vaguely that a similar problem was discussed here a while ago, but I can't remember what the cause was. Do a google search and see if you can find the thread, it may be of help.
this may get you started: https://www.google.com/search?q=stro...h=790&dpr=1.25
AND fill in your profile where you are and add the model/ year of bike you are riding to get better answers.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #4 of 5 Old 06-29-2019, 08:08 PM
locoblanco's Avatar
Sounds like a shorted ignition switch.
locoblanco is online now
post #5 of 5 Old 06-30-2019, 08:12 PM
Rolex's Avatar
Will it stay running forever or just a few seconds ?
On some bikes if the cooling fan is running when the bike is shut down the fan motor can feed energy back into the ignition system to keep the motor running but it will only run for a few seconds.
Do you get the same result if you shut the bike down with the kill switch, will the motor stop, do you get ignition lights up on the dash ?
What if you leave the bike in gear and use the kick stand to shut the bike off is it the same ?
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
