Battery Tender Pigtail Install Question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 13Likes
post #1 of 13 Old 06-23-2019, 05:41 PM Thread Starter
HiJincs's Avatar
2012 with an Eastern Beaver PC-8 Fuse Panel.
Do I install the Battery Tender pigtail directly to the battery or an un-switched terminal on the PC-8?
Searched but couldn't find an answer.
"I am ill equipped in the philosophies of failure"
When I die, show no pity, send my soul to Juggalo City.
Dig my grave six feet deep and put two Sidi's on my feet.
Put some leather over my chest and tell my family I did my best!
HiJincs is offline
post #2 of 13 Old 06-23-2019, 06:24 PM
Highwayman2016's Avatar
I believe the preferred method is straight to the battery.
2014 650 Strom
Highwayman2016 is offline
post #3 of 13 Old 06-24-2019, 05:19 AM
I ran mine to the unswitched part of the fuse panel (Eastern Beaver) that way I can also use it to power my air pump.
Bob S.
2017 Vstrom 650 Base model (White)
2018 Yamaha WR250R
Previous loves:
2017 Yamaha YZ250X
1982 Yamaha 650 Seca
1978 Honda CB550
1975 Suzuki GT380
1977 Yamaha RD400
1973 Can Am MX1 125 (bought while Mom was out of town)
Nicad is offline
post #4 of 13 Old 06-24-2019, 08:07 AM
I have mine going direct to the battery because I didn't want another stop at the EB along the way and with the extra wiring run that goes with it. Another point of failure for something that could be plugged in for days at a time (although I haven't used mine yet). I'm probably over thinking it though. There's probably no reason why running through the EB would pose a problem.
HiJincs likes this.
Houstrom46* is offline
post #5 of 13 Old 06-24-2019, 08:23 AM
Webfors's Avatar
Either works. I have mine directly to the battery via SAE -> Coaxial adaptor using my heated gear plug.
HiJincs and AZ Pete like this.
Two wheelz for realz!
Webfors is offline
post #6 of 13 Old 06-24-2019, 11:19 AM
dravnx's Avatar
Just make sure the PC 8 port and it's fuse will handle the current draw of the pump.
HiJincs likes this.
L2 DL650 Adventure
bike X miles=smiles
smiles ÷ bike=miles
miles ÷ smiles=bike.
It's simple math.
dravnx is offline
post #7 of 13 Old 06-24-2019, 12:13 PM
Coach23101's Avatar
Location: Seattle in the summer and East Cape, Baja in the winter. Perfect!
2013 Wee. I installed a 12 volt outlet with waterproofing cap and inline fuse from Amazon. And from Radio Shack (RIP) got a cig lighter adapter for the Battery Tender.
So I just pop it in the outlet in the garage.
Use the outlet for the air compressor as well.
No fiddling around.
Extended the outlet wires to the other side and installed a dual USB and Voltmeter port from Amazon. Monitor the battery level and have power for my phone and stuff.
Cheap mods and soooo convenient.
Coach23101 is offline
post #8 of 13 Old 06-24-2019, 04:00 PM
Rolex's Avatar
For your system to work as a charger you need power 24/7 and the way I read your post that means your volt meter will be working 24/7 too ???
I never use a tender but I do have power socket in my top box for charging phones and headsets, I can put them in the box to charge and walk away.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #9 of 13 Old 06-25-2019, 08:42 AM
Randolph's Avatar
I wired mine to the unswitched part of my PC8, just pick the correct fuse
HiJincs and notacop like this.
Randolph is offline
post #10 of 13 Old 06-25-2019, 09:09 AM
Motorpsychology's Avatar
The instructions for the actual Deltran Battery Tender brand say to connect directly to the battery in step 11. The rest of the safety stuff is about as severe as entering Chernobyl. ☢️ There is no copyright info on their .pdf instructions so I believe it is appropriate to post a link here:
http://products.batterytender.com/021-0123-man.pdf
HiJincs likes this.
18 wheels move the cargo, 4 wheels move the body, 2 wheels move the soul -unknown
“Of all the paths you take in life, make sure a few of them are dirt.” - John Muir
I visited the Air & Space Museum- didn't see a thing...
Motorpsychology is offline
