the 5200RPM "Givi Buzz" - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 10Likes
post #1 of 18 Old 06-17-2019, 02:56 PM Thread Starter
Anyone have any idea how to fix this?
I have a '19 Wee with these Givi bars and the 5200 buzz is making me lose my mind
vboost is offline
post #2 of 18 Old 06-17-2019, 03:04 PM
Webfors's Avatar
Lots of ideas on how to solve this. I solved mine by adding some silicone at the centre joint where the bars meet since my noise was specific to that joint. Others have a more severe buzz that can be resolved by adding weight to the bars to reduce the resonance.
vboost likes this.
Two wheelz for realz!
Webfors is online now
post #3 of 18 Old 06-17-2019, 07:52 PM
RestoRider2017's Avatar
Location: Apopka Florida NW of Orlando near a twist in the road and a hill on the horizon...
I loosened mine at the front center bolt with the allen head bolts on the sides just slightly loosened.
Spread the center appart in front to expose the joint (where the orings are ) I wrapped the ends
of the joint with about 3 to 5 turns of black electrical tape. When installed I made sure the orings
sat up in the pipe on each side at least 1/4" I used a small allen wrench to push them where I needed them.
Replaced the front cross bolt with a grade 8 bolt and nylon locking nut.
after everything was tightened back up ___ No buzz - no fuss at any speed.
richlandrick, Webfors and vboost like this.
2017 DL 650 , Shad 23 side bags, Givi crash bars, 32 watt LED driving lights ,
Goldwing pegs, silver front fender, Lazer cut aluminum Chain guard, Madstad 20" windshield
light smoke tint , Blu/blk Driven Racing Billet bar ends.
"any comments made on this forum are purely for amusement purposes only.
not to be confused with actual knowledge"
RestoRider2017 is offline
post #4 of 18 Old 06-17-2019, 11:09 PM
christophermarkfoster's Avatar
Mine was from the bolt spacer not being pinched tight enough. Reefed down on it good and it went away. But it was driving me nuts too. You can tap the bars with a rubber mallet and see if you can hear the sound. That helped me find my problem.
Chris
1. 2004 DL1000
2. Next bike
3. Next bike
4. Next bike
christophermarkfoster is offline
post #5 of 18 Old 06-18-2019, 12:43 AM
KSM
KSM's Avatar
I actually ground the spacer shorter by a couple mm then tightened the bolt that goes through it and that solved it completely.
richlandrick likes this.
2012 DL650A (purchased Dec 2017)
2005 DRZ400S (sold Dec 2017)
1972 Norton Commando (sold 1984)
1978 Suzuki DR370 (sold 1982)
KSM is offline
post #6 of 18 Old 06-18-2019, 05:16 AM
Griff2's Avatar
One chap on here mentioned on another thread that he filled the inside of the crashbar tubes with an expanding insulating foam. He suggests that doing that cured the buzz on his bike. It would appear that one or two others followed his advice with the same result. Tbh I suppose it cant hurt to do so.
Griff2 is offline
post #7 of 18 Old 06-18-2019, 07:22 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
Is this a 650 Givi phenomenon? No doubt that some are expereincing it.
I don't ride constatntly at 5,400 rpm much, but have never expereinced a buzz problem with my Givi bars on Vee2.
I'll bring this subject to the attention of Givi.usa. But it seems up to "Givi.it" to do soemthing different.
Webfors likes this.
richlandrick is offline
post #8 of 18 Old 06-18-2019, 08:56 AM
Webfors's Avatar
I think the 650 is so smooth and quiet that it's more obvious. The 1000 makes enough noise and buzz on it's own that it would just blend in
post #9 of 18 Old 06-18-2019, 09:00 AM
Hogges's Avatar
My 2017 Wee doesn’t buzz with the Givi bars. Maybe loosen all bolts and while making sure the front (cross) connection is well aligned and has the o-ring in place tighten everything again evenly and do the front last. To remove any potential tension or loose play.
Hogges is offline
post #10 of 18 Old 06-19-2019, 07:12 PM
I did mine almost exactly like you described. And went back over it twice. Loosened the frame mounting bolts slightly, Front bolt tightened
down and retorque the frame bolts. Nothing eliminated the buzziness until I wrapped the joint and repositioned the o rings.
The bolt I used was a little bit larger in diameter than the stock bolt. So I had to drill the mount out slightly larger to fit.
But it's been this way for more than 2 months and is whisper quite now.
