Mounted a rear tire - something stuck inside - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
  • 1 Post By Bazooka Joe
  • 3 Post By Toadster
post #1 of 10 Old 06-16-2019, 12:59 PM Thread Starter
Hello,
For the first time, I decided to mount my own new rear tire. To protect my rim I used cut up pieces of a windshield antifreeze container. When I finally finished up mounting the tire, I rolled it around to discover that something had fallen inside . The only thing I can think of it being is one of the strips of plastic I used as a rim protector but it feels heavier than that. I can feel it on the outside of the tire when it falls to the bottom. Is it safe to just leave whatever it is in there?
Toadster is offline
post #2 of 10 Old 06-16-2019, 01:41 PM
no way jose. you got to break the beads and remove the tire enough to get whatever is there out.!!
congratulations, you are having a good learning experience and probably won't have that problem again.
RLBranson is offline
post #3 of 10 Old 06-16-2019, 02:27 PM
Maybe get a NoMAr set of tools or such?
https://www.google.com/search?q=noma...hrome&ie=UTF-8
post #4 of 10 Old 06-16-2019, 02:37 PM
yep, ya gotta get whatever is in there outta there. The good news is, you probably don't have to take the tire completely off. I'd guess you only need to pop the bead on one side and reach in
Yarz1 is offline
post #5 of 10 Old 06-16-2019, 02:57 PM
Bazooka Joe's Avatar
Buy two pairs of these rim protectors.
https://www.rockymountainatvmc.com/p...m-protectors-p
locoblanco likes this.
18 1000 XT yellow. Bunch of goodies installed.
2015 Yamaha WR250F- Street plated woods bike
Previous rides- about 25 different bikes, mostly dirtbikes.
Bazooka Joe is offline
post #6 of 10 Old 06-16-2019, 04:48 PM
chicago's Avatar
I use pieces of leather from an old belt but I'm not as careful using them as I should be. I use motion pro bead breaker.... makes it pretty easy. but yeah you need to remove object before riding.
14 tooth for me
chicago is online now
post #7 of 10 Old 06-16-2019, 08:20 PM
Stalky Tracker's Avatar
What everyone else said, it's gotta come out.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #8 of 10 Old 06-17-2019, 08:06 PM Thread Starter
Thanks for all of the input. So even if it's just a piece of plastic it will cause harm? The tire seems fine at 80km/h.
Toadster is offline
post #9 of 10 Old 06-17-2019, 08:50 PM
Brockie's Avatar
Sure, at speed it will stay in one position - but every time you stop, and then start, it will reposition itself. Any damage will depend on what type of plastic, and how sharp the corners and edges are.
Not worth the risk.
Brockie is offline
post #10 of 10 Old 06-20-2019, 12:11 AM Thread Starter
I went ahead and removed the two pieces of plastic that were spinning around in there. I was able to just break the bead on one side, pry the tire from the rim, and slowly push the plastic towards the gap by pressing the plastic against the rim with a screwdriver and pivoting up. It was a bit of a pain and took about 2 hours but at least they're out.
Gert, Brockie and Motor7 like this.
Toadster is offline
