650xt / 1000xt handlebars and wrists - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
  • 3 Post By Gert
  • 1 Post By PeteW
post #1 of 9 Old 06-12-2019, 04:19 AM Thread Starter
because I have often problems with my wrist (from dirt bike riding) I wonder which of these bikes has better handlebars for your wrist?
Looks like 650xt has more twisted bars to the rider, and xt has fat bars and less twisted. How are your bars for your wrists?
offnote is online now
post #2 of 9 Old 06-12-2019, 04:40 AM
Change the bars or fit risers, it's about the cheapest mod you can do to a bike.
If you happen to be somewhere in the EU and can't do that, the 1000 is better stock though you may have to rotate the bars back a little.
PeteW is online now
post #3 of 9 Old 06-12-2019, 04:53 AM
Gert's Avatar
Some riders make use of grip puppies to reduce the hand numbness. Wrist tension could be from holding the handlebar too tightly. Have you perhaps had time to read any of these posts, for some ideas on handlebar options, https://www.vstrom.info/Smf/index.php/board,70.0.html? Some good pix shown on the sticky thread, https://www.vstrom.info/Smf/index.php/topic,936.0.html. Also some interesting readig https://www.stromtrooper.com/mainten...ed-risers.html
Gert is offline
post #4 of 9 Old 06-12-2019, 02:19 PM
Stalky Tracker's Avatar
What he said.
OEM handlebars bothered my wrist so I swapped them out for ProTaper ATV High bars. Lots of other choices out there too.
2006 Suzuki V-Strom DL650K
1986 Honda Shadow VT700C
1974 Suzuki TM-250
1965 Suzuki 80
Stalky Tracker is offline
post #5 of 9 Old 06-12-2019, 05:04 PM Thread Starter
not sure what bars riser have to do with hands position? mostly will be seating, it's a touring bike.
personally don't like risers, don't use them on my ktm exc adn tenere.
post #6 of 9 Old 06-13-2019, 04:29 AM
Gert's Avatar
Sit on your bike, with a comfortable posture and your eyes closed. Lift your arms to handle bar height, but don't try reach to grab hold of your handle bars. Have someone take a pix of your arm length and wrist direction. This should help you diagnose if a handle bar hand position and reach problem. From this data, you can make adjustments / additions accordingly.
Brockie, offnote and Nicad like this.
Gert is offline
post #7 of 9 Old 06-13-2019, 05:40 AM
Risers don't only lift the bars, you can get risers that go up and back. Plus with the base of the bars higher you can usually rotate them back bringing the ends in closer to your body.
Bars that have your wrists at full lock with arms straight out might be comfortable with elbows bent.
The advice on sitting there with eyes closed is right on, the trick is finding the option that'll get the bar ends under your hands
I don't care that you don't like risers , sometimes that is what's needed to solve the problem.
ocoas likes this.
PeteW is online now
post #8 of 9 Old 06-13-2019, 10:11 PM
scab's Avatar
Aside from height, angle of grip seems to be what bothers my wrists. I had a fantastic FJR 1300, except the angle was slightly awkward on my wrists and made them either go numb or ache. I'm riding an '18 650 XT and I find the angle very good for my wrist comfort. I did add setback risers, but that was more for my back problems so that I would not have to lean forward much.
If you're not living on the edge, you're taking up too much space.
scab is offline
post #9 of 9 Old 06-13-2019, 10:57 PM
blaustrom's Avatar
I don't like the amount of pull-back the OEM bars have and replaced them with bars with less pull-back. I even moved the bars from my WEE to the V2 so I would not need to experiment again.
I like Gert's suggestion a lot. Worth trying.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
