Seriously??? Lights out - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 8Likes
post #1 of 17 Old 05-31-2019, 10:50 AM Thread Starter
Fynlcut's Avatar
High beam only is a crappy way to drive to work. Not only do I blind everyone, there is not much direct illumination of the road.
This is the second time in 6 months. I wonder if I have an issue.
Freaking hate changing light bulbs.
Fynlcut is offline
post #2 of 17 Old 09-19-2019, 09:36 AM Thread Starter
Fynlcut's Avatar
Welp, another headlight went out.
I dont remember the last time I changed a headlight in my car.
I change my headlight more often than my oil!
Fynlcut is offline
post #3 of 17 Old 09-19-2019, 09:56 AM
p38arover's Avatar
I've never changed a headlight bulb on a bike.
Two things:
Are the bulbs of good quality, not cheap Chinese stuff?
What is the system voltage with the engine at speed?
Ron B. VK2OTC
2007 Yamaha XJR1300
RIP Bucko
1979-2008 - Riding on forever
p38arover is offline
post #4 of 17 Old 09-19-2019, 10:04 AM
something is definately wrong.
Is it OEM?
My bike is 08 and OEM. Hadn't had to replace the bulb yet.
I did add the Easter beaver h4 relay light kit.
2008 Suzuki Vstrom DL650
2013 Yamaha WR250R
2004 BMW R1150RT
2002 Ducati 998 Superbike
2001 BMW R1200C Phoenix/Independent
1982 BMW R100RT
2003 Kawasaki Ninja 250r - Sold
1985 Yamaha FZ-750 - Sold
1984 Kawasaki GPZ-750 - Sold
bmwguy is offline
post #5 of 17 Old 09-19-2019, 10:19 AM
You did not mention your bike year or the bulb. If it is an H4, consider going to an LED - it is a plug and play replacement that I have done. The F2 is your best bet, and this is probably the best price...LINKY. I put them on my DL650 and love them. Btw, they are a whole lot easier to swap on the Suzi than on my ST 1300.
If you want more background on LED headlights, read this thread...Info on LED Headlights. The author of that post is extremely knowledgeable about LED lamps and helped design the shield on the lamp that provides a cut off of the beam to avoid blinding oncoming traffic.
Gert and slovcan like this.
Ratchet is offline
post #6 of 17 Old 09-19-2019, 12:01 PM
Motorpsychology's Avatar
Buy motorcycle-specific headlight bulbs. they are designed to work in an environment where there is greater vibration and less heat ventilation typically found on motorcycles. If you are already installing MC bulbs, you may have a grounding issue.
I gotta go with the flow here; the only headlight bulbs I've ever installed on bikes was for increased wattage over OEM. I've never had an OEM or aftermarket MC-specific bulb burn out.
Gert likes this.
"I never said half of that stuff."-Confucius
Motorpsychology is offline
post #7 of 17 Old 09-19-2019, 01:03 PM
I saw the light, it was LED. Less current draw, more and better light, and they will see me out.Put in LED and worry about other things. I am going to slightly lower my headlights because they put more light on the road. the less amp draw is great for the small cheap wiring in the electric system. don't even need relays.
Also they are more tolerant of the high and low voltages that burn out incandesant bulbs.
RLBranson is online now
post #8 of 17 Old 09-19-2019, 01:21 PM
BC Rider's Avatar
Never had a bulb fail on me. So something odd is going on with yours. Touching the glass portion of the bulb with your fingers or putting it down on a surface can contaminate the bulb, leading to early failure.
Brockie and Motorpsychology like this.
13 DL650 Current ride
80 CX500D
77 XS360
78 XS750
76 CB360T
BC Rider is offline
post #9 of 17 Old 09-19-2019, 01:22 PM
Spec's Avatar
What bulbs are you using?
I've found that regular ol' generic bulbs like you can buy at Walmart last longer than more premium bulbs like Silver Stars (for example, can get those at Walmart too!)
Typically a low beam headlight bulb will last me at least a couple of years. I don't run my high beam much so it lasts forever!
Big B likes this.
Spec is offline
post #10 of 17 Old 09-19-2019, 02:24 PM
chicago's Avatar
twice in 6 months is odd. I don't recall burning a headlight bulb for many years.
over voltage or low quality bulbs?
14 tooth for me
chicago is offline
